Even though it is pretty rigid, I will build a frame out of angle iron to support it. I'm going to put a thin rubber seal around the top edge, add a couple small draw latches to the front & cut a slot in the front pocket for my power cutoff switch.
If I drill some drain hole in the bottom, do I need to vent it?
