Doing some more searching on the small 12VDC air conditioner and the company the builds them, reveals some more info.
Some highlights:
They are using high quality Danfross compressors, and German control electronics.
I found two different prices listed-- $750 and $474! $474 is a great deal for one of these! Maybe a group buy of these things can get it down even more, or at least save shipping costs?
Warranty is 1 year, and they have a 30 day money-back. The company seems to be a small cottage-industry type business.
Product Description:
Model: DC1
Compressor: 12V or 24V compressor
Cooling capacity: 300 watts (1020 Btu)
Cooling space: 6 ft x 4 ft x 6 ft (144 ft3)
Electricity: DC 12V @ 8.0A & DC 24V @ 4.0A
Refrigerant: HFC-134a
Ambient air temperature: 24 deg C to 33 deg C
Off-coil (breeze) temperature: 18 deg C to 21 deg C
Wireless Remote Control: Microprocessor (temperature, thermostat)
Temperature control: IC thermostat
Dimensions:: (L x B x H)
Cooling unit (7.5 kg): 31.75inx5.75inx10.5in (805mmx145mx265mm)
Condenser unit (11kg): 14.5inx10.0inx9.0in (368mmx254mmx229mm)
Casing: Plastic and painted steel
Weight (approximately): 18.5kg
Unit Price: USD$750
Origin: Malaysia
Supply Ability: 4 weeks for delivery
12/24V AIR CONDITIONER
PRODUCT FEATURES:
~ Very quiet in operation
~ The compressor is used together with an electronic unit which provides overload protection and destructive battery discharge
SPECIFICATIONS:
~ Operates on 12 OR 24 volts direct current system from battery or DC generator
~ Uses R134a refrigerant which is CFC free
~ Current consumption for 12V system is 7.5 amperes and for 24V system is 3.75 amperes at evaporating temperature of +10 degrees Celcius.
~ Cooling capacity is about 300 watts
~ A typical operating conditions in a room of 6ft by 4ft by 6ft (144 cubic feet) is shown below:
The whole system's current consumption: 6.5 to 8 amperes
Ambient temperature: 25 to 33 degrees Celsius
Condensing temperature: 40 to 45 degrees Celsius (135 to 152 psig )
Evaporating temperature: 8 to 12 degrees Celsius (42 to 53 psig)
Room temperature: 23 to 25 deg C
Off-coil (breeze blowing from the evaporator): 18 to 21 deg C
~Weighs about 15 kg
~Color bond and fibre glass panels
NOTE: The cooling capacity of the air conditioner is about 300 watts, so temperature drop inside the room is limited. But due to lower humidity and between 5 to 10 degrees Celsius lower than outside air ambient temperature, it will provide a reasonable comfort zone.
USES
~ small room, approximately 6ft by 4ft by 6ft or approximately 140 cubic feet
MODELS
1.Model DC1
Dimension: LENGTH (IN) x BREATH (IN) x HEIGHT (IN)
Evaporator (cooling unit): 14.5 x 6.5 x 9.0
Condenser assembly (with compressor): 14.5 x 10.0 x 9.0
NOTE: The design may be slightly different from the photo shown because of technical development, and design improvement and evolution.
WARRANTY
~ One year warranty
~ Your money back guarantee if you are not satisfied within 1 month
PRICE
~ Air conditioner @USD474.00 each ex-Miri, Sarawak, Malaysia
Product Description
* Operates on 12 OR 24 volts direct current system from battery or DC generator
* Uses R134a refrigerant which is CFC free
* Current comsumption for 12V system is 7.5 amperes and for 24V system is 3.75 amperes at evaporating temperature of +10 degrees Celcius
* Cooling capacity is about 300 watts
* A typical operating conditions in a room of 6ft by 4ft by 6ft (144 cubic feet) is shown below :
a) The whole system's current consumption : 6.5 to 8 amperes
b) Ambient temperature : 25 to 33 degrees Celcius
c) 40 to 45 degrees Celsius (135 to 152 psig)
d) Evaporating temperature : 8 to 12 degrees Celsius (42 to 53 psig)
e) Room temperature : 23 to 25 deg C
f) Off-coil (breeze blowing from the evaporator) : 18 to 21 deg C
*Dimension : Length (in) x Breath (in) x Height (in)
*Evaporator (cooling unit) : 14.5 x 6.5 x 9.0
*Condenser assembly (with compressor) : 14.5 x 10.0 x 9.0
Dongfar Machinery & Parts Sdn Bhd [Malaysia]
Business Type: Manufacturer
Industry Focus: Air-conditioner , Refrigerator & Freezer
Number of Employees: Less than 5 People
Annual Turnover: Below US$1 Million
Main Market: Worldwide
Company Overview
We are manufacturer of portable 12V DC freezer, refrigerator and air conditioner. The compressor is madeby a renowned compressor manufacturer in Germany. Hence the quality is assured.
Our products, 12V DC freezer, refrigerator and air conditioner, have been exported to Korea, Turkey, UAE, Australia, UK, Canada and the USA.
Currently we are negotiating distributorship in the USA and other parts of the world to provide better after sales service.
We are manufacturer of :
1. 12 and 24 volts dc REFRIGERATOR : DcFRIDGE
2. 12 and 24 volts dc FREEZER : DcFREEZER
3. 12 and 24 volts dc AIR CONDITIONER : DcAIRCON
Using compressor with German technology as the main component. Our compressor with German technology means that you are assured of the quality and trouble-free performance. We hope it gives you years of happy, fault-free and reliable service. We have all the confidence that it will. We have put in hours of patience and skills that go into producing every product that leaves our plant. We back up our product with YOUR MONEY BACK GUARANTEE and ONE YEAR WARRANTY.
Dongfar Machinery & Parts Sdn Bhd is in the business of manufacturing 12 and 24 volt direct current portable freezers and air conditioners. Our products are made locally using the Danfoss compressor and electronic control unit from Germany.
We back all our products with a money back guarantee and a one-year guarantee. With that, you are assured of extreme top quality.
Contact Name: Mr Lee Heng Soon
[email protected]
Tel: 006-03-90747913/90753888
Fax: 006-03-90751688
Address: Lot 19, Lorong 3A, Kawasan Perusahaan Cheras Jaya, Jalan Cheras , 43200 Cheras, Selangor, Malaysia
Contact: Mr Lee Heng Soon
Address: 895, Jalan Krokop 10
City: Miri
Zip/Post Code: 98000
State: Sarawak
Country: Malaysia
Telephone No: 60-85-436433
Fax No: 60-85-436433
Dongfar Machinery And Parts Sdn Bhd
895, Jalan Krokop 10,
Miri, Sarawak
Malaysia 98000
Tel: 6-085-436-433
Fax: 6-085-436-433
Contact: Lee Heng Soon - Managing Director
Company Email:
[email protected]
Contact Person: Mr Lee Heng Soon
Contact Person Email:
[email protected]
Address: 895 Jalan Krokop 10
Postcode: 98000
City: Miri
State: Sarawak
Country: Malaysia
Telephone No: 60 85 436433
Fax No: 60 85 436433
They also build some very cool looking 12VDC frig and coolers for cheap!
The following sites were culled for the above info:
http://www.mybiz.net/member/dongfar/
http://www.alibaba.com/catalog/121296/12V_DC_Air_Conditioner.html
http://my.ecplaza.net/dongfar/
http://www.ibeli.com/showroom/default.asp?memberid=256
(This next URL is cut in half!- cut and paste them together)
http://www.pickandpost.com.my/dsp_posti ... 6&type=235
&subcat=Common%20Supplies&sec=Electrical/Electronics&pageval=1&searchval=&listval=&location=All&review=0
