Page 1 of 1
harbor freight trailer ( lower axle)
Posted:
Sun Apr 22, 2007 7:52 am
by seahorse
Did anybody lower the axle on the 1175 lb trailer. ( put axle on top of springs) with good results????????
Posted:
Sun Apr 22, 2007 5:36 pm
by Ira
Most people DO it that way.
I didn't, because I'm a troublemaker.
Seriously, it really lowers the profile, but I didn't care about that, especially since I'm towing with a big truck.
Posted:
Sun Apr 22, 2007 7:30 pm
by toypusher
If you put the axle on top of the spring, then you will probably have to cut a section out of the spring bracket for the axle to have enough travel without hitting.
Posted:
Sun Apr 22, 2007 7:43 pm
by seahorse
Thanks guys.........I was worried about U bolt, and plate strength.
Posted:
Sun Apr 22, 2007 7:52 pm
by toypusher
seahorse wrote:Thanks guys.........I was worried about U bolt, and plate strength.
Should not be a problem, lots of folks have done it before you!!
Posted:
Sun Apr 22, 2007 8:07 pm
by seahorse
toypusher wrote:seahorse wrote:Thanks guys.........I was worried about U bolt, and plate strength.
Thats what I wanted to hear.......thank you!
Lowering a Harbor Freight Trailer
Posted:
Fri Apr 27, 2007 10:06 pm
by MrBuzz
I have that exact same trailer. I notched the sub-frame assy and then moved the axle to the top of the spring. Another hint I got from a fellow builder...you have to turn the center bolt upside down so that the axle and the brackets line up correctly. To do that I had to also modify the leaf spring by clamping the spring in a vise, then unbolting the center bolt and turn it upside down.
Other builders also suggest moving the axle back 6-7 inches so the trailer is more stable when towing. I did that also, ended up drilling some new holes for that too...but it turned out real nice.
Check out my album for photos...
Posted:
Sat Apr 28, 2007 8:01 am
by Arne
Notching works, but be careful you have enough spring clearance. Jack up the FRAME on one side enough to lift the wheel off the ground and see how much you frame/axle distance you have unloaded.. then lower the trailer and see what is left with all the weight on it.
On my 1800# trailer, I did the same thing. Wound up with 2 inches of frame/axle clearance.. worked fine for 10,000 miles till I went through a construction zone, hit a huge pothole, the trailer bottomed out on the axle very hard, and I suffered catastrophic tongue failure (trailer left car)...
The ubolts and plate were never a problem.... I have since relocated the axle under the spring back to it's original position.
Posted:
Sat Apr 28, 2007 10:42 am
by seahorse
Thanks for your comments.....all are appreciated. Steer clear of all potholes, they leave a mark!
Posted:
Sat Apr 28, 2007 7:05 pm
by Arne
and your point is?
Posted:
Thu May 03, 2007 12:33 am
by Nic
Arne wrote:Notching works, but be careful you have enough spring clearance. Jack up the FRAME on one side enough to lift the wheel off the ground and see how much you frame/axle distance you have unloaded.. then lower the trailer and see what is left with all the weight on it.
This sounds like a real good idea for mine. Now that i have larger wheels on the trailer it sets up too high for my beetle. And turning the drop hitch over is not doing it either.
Im thinking notching the frame sounds kinda scary. How much do you notch it? And if i didnt want to notch it do you think i would be fine as long as i dont hit any holes? Anyone have a pic of their notch?
Posted:
Thu May 03, 2007 12:17 pm
by angib
Nic wrote:Im thinking notching the frame sounds kinda scary.
The notch is in the piece of angle that holds the spring, not in the main frame itself.
Andrew
Posted:
Thu May 03, 2007 12:59 pm
by SkipperSue
I had lowered my axle, cut the notch an all that. But I decided to build a 5x8 on a 4x8 trailer, and I didn't like the fact that the fenderwells would stick up too high in the cabin. So I switched the axle back the way it was, all but moving the wheels back.
Here is a pretty good link of how I lowered mine before I raised it.
Hmmm, that kinda sounded like a politition from a few years ago.
http://www.tnttt.com/viewtopic.php?t=11635
Posted:
Thu May 03, 2007 4:47 pm
by Arne
I notched my frame, and did it all as described. It worked great till I went through a construction area, hit a huge pot hole and ripped the tongue off the frame. It lasted for 10,000 miles before it broke... I think what happened was my 2" of clearance between the axle top and the frame got used up, and it bottomed so hard, it broke the tongue.
Now, I'm not saying not to do it, but be aware of the potential consequences of your changes.... shocks might have helped, I don't know.. but, I put the axle back into its stock position and there it will remain. Trailer weighs 1,220# with a tongue weight of 95#.
