I think I could of made it water proof the way it was by double sealing, but I would rather have it the right way. I dread the thought of making a new door, besides I would have to order another gallon of Durabak.
doug hodder wrote:Elmo...which way is it warped...so it curves in or out? and I'm assuming it is top to bottom not front to back right? I had a door that warped on my first tear...not like 1/2"...but what I did was run a bunch of kerfs ( a lot) with a circular saw across the back of the door after the window was cut out on it, about 1/2 way through the material and make it more flexible...then set it up absolutely flat and squeeged epoxy into the back to fill the kerfs...then covered it with the interior paneling. It took it all out, but if it is already skinned with the interior paneling, you might have to do something like a wood cleat, and that could be decoratively done. It worked for me, I haven't had good luck with just weighting it and having it come out okay...others opinions may vary...Doug
Podunkfla wrote:Elmo... I think Doug has the best solution I know of. I have built more than my share of kitchen cabinets, etc. over the years with a warped door or two. I have rarely had any success straightening them. Since yours are being painted on the outside, matching wood isn't a problem; I would just cut out another door and be done with it.
elmo wrote:Hi Brick...The making the new door would be way to easy.The bad part is that it is already Durabak'd/painted...I need it this weekend...I have to order a whole gallon of Durabak at $90 a gallon and takes at least a week and a half to get here. I was hoping someone had something that worked for them that would work for now.
Ira wrote:elmo wrote:Hi Brick...The making the new door would be way to easy.The bad part is that it is already Durabak'd/painted...I need it this weekend...I have to order a whole gallon of Durabak at $90 a gallon and takes at least a week and a half to get here. I was hoping someone had something that worked for them that would work for now.
Pull the "make lemon out of lemonade" cliche out of your files.
And put on your thinking cap:
If you find you DO have to build a new door, instead of Durabak, why don't you skin it with that matching diamond plate (too expensive?) or something else cool? It could wind up looking better to you than just the Durabak.
But I would make every effort to fix this one first.
Keith B wrote:Don't know if it'll work or not but... I was going to build my doors out of 3/4" 9 layer plywood and wrap the door edges in either steel channel or aluminum channel to keep 'er straight and flat, etc... so... can you wrap the edges of your door?...also, I heard some attach a door stiffener to the inside...this might get you by for the upcoming weekend and you can "fancy" it up later. I was told if you do it right, you can use the stiffener as a handle/towel rack, etc...maybe a thought.
Keith B wrote:I'd think you can make your own door stiffener... Any kind of oak, steel tubing, etc. will stiffen it.... that'll get you by for now since you're somewhat pushed for time...then later you can take the stiffener off and figure out a "fancier" way of doing things... and who knows...with the stiffener on, you might think of another creative way to mount it and use it.. The hinge side should be okay...but put a 3/4x3/4 steel sq. tube or something on the other side and that should stiffen 'er up...
bobhenry wrote:Was the door only sealed on the painted side when it was stored ?
( inside bare wood ! )
Keith B wrote:I hate to be Mr. Negative...but I would guess, that altough it appears the door is getting better with weight...it will most likely come back once humidity and the elements get to working on it....I'd still stiffen it up.
