Gas Shocks for Hatch Question
Postby Classic Finn » Thu May 03, 2007 9:52 am
Dear Friends
I took a lil roadtrip and found our gas shocks ... that are stainless steel
and the brackets for them..
Now how do I go about finding the right "point" to install them on our hatch so I dont make a mistake on it ..
Here is a pic of the assembly.
Classic Finn
Classic Finn
Midnight Sun Voyager
Images: 146
Postby rbeemer » Thu May 03, 2007 11:04 am
Rick
If ducks had scales, would fish quack?
rbeemer
Postby Classic Finn » Thu May 03, 2007 12:13 pm
The seller said that I have to find the center point of the weight on the hatch :thinking: :thinking: :thinking:
I guess I dont get his thoughts on this.. :?
Classic Finn
Classic Finn
Images: 146
Postby rbeemer » Thu May 03, 2007 12:21 pm
What is the kilo rating on them that there shocks. I think more important is where they can be put so the hatch will fully open and close
Rick
rbeemer
Postby Classic Finn » Thu May 03, 2007 12:34 pm
rbeemer wrote:What is the kilo rating on them that there shocks. I think more important is where they can be put so the hatch will fully open and close
The rating is 40 to 140kg.
Classic Finn
Classic Finn
Images: 146
Postby rbeemer » Thu May 03, 2007 12:48 pm
Those are some heavy duty shocks 88- 308lbs each
There is a thread on the forum with a formula and directions for placing them. Search for Gas Struts. I do not think you have to worry about finding the centerpoint of weight because your hatch is not that heavy. If you can go look at truck canopies you can see how they position their struts/shocks for the rear door or look at rear door of a hatchback automobile.
Rick
rbeemer
Postby Classic Finn » Thu May 03, 2007 12:53 pm
rbeemer wrote:Those are some heavy duty shocks 88- 308lbs each
Rather be Safe than Sorry especially with little folks near ...
Classic Finn ;)
Classic Finn
Images: 146
Postby Classic Finn » Fri May 04, 2007 2:08 am
Ok this is what I meant..for anyone else that this may help in the future. Now its figured out.
Classic Finn
Classic Finn
Images: 146
Postby BrwBier » Sat May 05, 2007 7:32 am
You could take a fish scale and lift the hatch to the hight you want it open to and when you find the point that the scale reads in the middle of the range of the shockes attach them at that point. Example, find the point where the scale reads 100 kg. when lifting with the scale. Does that sound reasonable? :thinking:
Brwbier
BrwBier
Images: 100
Postby sdtripper2 » Sat May 05, 2007 8:20 am
Here are some sources for this subject:
Formulas and planning for Struts
Good explanation on sizing struts
and tools for calculating the size
http://www.easyliftsprings.com/contact/ ... urown.html
http://www.watertanks.com/calc.asp
Steve T's (sonetpro) formula for struts
http://tinyurl.com/zsxpw
Go here and scroll down to the strut area for more information:
http://tnttt.com/viewtopic.php?t=11210
sdtripper2
Search Garoux
Images: 168
Postby angib » Sat May 05, 2007 11:13 am
Heikki (and others),
In the post where you fond those drawings you will find the recommendation from Grant for where to put the ends of the gas struts - which is quite different from what I had drawn - it has the strut connected to the hatch fairly near the hinge, but connected to the body well away from the hinge. This has the result that gas strut pushes the hinge closed when the hatch is down - my way, the hinge is being pushed apart by the strut.
I decided not to remove those drawings as the thread would stop making sense if I did that - but maybe I should do so to avoid confusion.
I would draw you a new diagram using Grant's dimensions, but I'm away from home and don't have the time or software here.
Andrew
angib
5000 Club
5000 Club
Images: 231
