Fender mounting
Fender mounting
Postby slipperyd12 » Fri May 04, 2007 10:17 pm
Hi All
Has anyone put any kind of material between your fender and the camper? I have .032 sides and I am mounting diamond plate aluminum fenders. I wanted to use just the brakets at the front and back of the fenders. The thought of drilling a mounting hole in the side of my trailer just doesn't sit well with me. The only problem is, if the fender moves any the diamond plate will eat up the side of the trailer. :thumbdown: I thought I had seen some body moulding that might work. But I wanted to see if anyone had tried just using the front and back bracket only. I am getting real close to finished. After the fenders the hatch is the only thing left. My album shows my progress. Thanks John
slipperyd12
Images: 67
Postby sdtripper2 » Fri May 04, 2007 10:47 pm
John:
Some have a bracket made that is attached to the frame so as to have the
fenders free floating away from the side of their trailer.
If a free floating frame isn't your choice, here are a few threads that might help you in your decision making?
http://tnttt.com/viewtopic.php?t=679
http://tnttt.com/viewtopic.php?t=5083
http://tnttt.com/viewtopic.php?t=7859
http://tnttt.com/viewtopic.php?t=7632
sdtripper2
Search Garoux
Images: 168
Postby Keith B » Mon May 07, 2007 10:36 am
I did not drill into the side of my camper... two brackets front and back, rubber sandwiched... check album for details.
Keith
"Work and work and do your best! Paint and putty will do the rest!"
Keith B
Postby sid » Mon May 07, 2007 11:02 am
Here is what bledsoe3 did on his..... I'm not sure if he attached it to the side anywhere.
sid n side
"If you're going through hell, keep going......" Winston Churchhill
Side by Side - completed October 2008
sid
Images: 194
Postby bledsoe3 » Mon May 07, 2007 12:19 pm
sid wrote:Here is what bledsoe3 did on his..... I'm not sure if he attached it to the side anywhere.
I just put a bead of silicone on the fender. No holes in the side of the trailer. Let me know if you have any questions.
bledsoe3
Images: 112
Fender mounts
Postby slipperyd12 » Tue May 08, 2007 5:43 pm
Thanks for the replies,
I put a bracket in the front and back and it just was not sturdy enough.
So then I drilled two holes in the side of the camper and put silicone around some threaded studs. Then I tightened a flanged nut against the side of the trailer. Drilled two holes in the fenders and you can now stand on them ( not recommended) :thumbsup: I have worked alot the past two days on my camper check out my album. One or two more weeks and I will be finished. I ordered a temperature stick that should be here Thursday. I have had problems annealing. It ends up being a beat and bang instead of bending. Thanks John
slipperyd12
Images: 67
