Removable A C. The way i did it
Postby JIML1943 » Tue May 08, 2007 10:00 am
Supply air is on the left,return air right with low voltage RV t stat,
4"return duct runs across bottom of blanket storage.
Side view of unit hooked up and running
Duct openings are supply on top return on bottom black outlet in between is low voltage connection.
1"id square tube welded to frame.
1" od square slides in to support ac unit.
Closed up and ready for travel.
A view of the unit outlets top is supply bottom center return air bottom right is outside air. In the cabinet i installed a 12 volt relay to control A C unit
wired fan to turn off with compressor, might install another relay later to allow fan to run alone. Oh by the way it works great, used last week.
Some days all you can do is smile and wait for some kind soul to come along and pull your ass out the bind you've gotten yourself into.
Happy camping Jim & Barbara
JIML1943
Images: 71
Postby tonyj » Tue May 08, 2007 10:17 am
That's a nice departure from the other ducted installations. :thumbsup:
tony
tonyj
Images: 160
Postby madjack » Tue May 08, 2007 1:04 pm
...nice setup :thumbsup: ........................................ 8)
Postby Ira » Tue May 08, 2007 2:04 pm
I'm confused:
Is that an extra enclosure that covers the entire unit?
And how do you adjust the settings?
Here we go again!
Ira
Forum Storyteller
Images: 118
Postby JIML1943 » Tue May 08, 2007 2:29 pm
Hey Ira i threw away the front cover and made one out of aluminium. it's controlled by the t stat in the cabin.
JIML1943
Images: 71
Postby toypusher » Tue May 08, 2007 2:34 pm
Jim,
Very nice setup!! Great job!
BTW: Your Yahoo pics don't seem to be 'shared' or 'public' and I can not see them.
toypusher
Images: 324
Postby JIML1943 » Tue May 08, 2007 2:54 pm
They are shared now. Thanks toypusher
JIML1943
Images: 71
Postby Ira » Tue May 08, 2007 3:20 pm
I still don't get it:
Aren't the unit controls exposed to the elements? They face the tongue, right? Not the cabin?
Or is was this not a window shaker to begin with?
My limited mind sees manual knobs and buttons, but I don't see them on the unit.
Edit:
Wait. I think I figured it out. Takes me long, because I'm a retard.
This was a window shaker, the on-unit controls face the CABIN, but are protected from the elements by your new enclosure.
Duh???
Here we go again!
Ira
Forum Storyteller
Images: 118
Postby JIML1943 » Tue May 08, 2007 3:28 pm
Hey again Ira The coils face the tongue the controls that used to be behind the cover with the sa & ra outlets are gone it is controled from inside cabin.via t stat.It is 5000 BTU window unit.
JIML1943
Images: 71
Postby toypusher » Tue May 08, 2007 4:17 pm
JIML1943 wrote:They are shared now. Thanks toypusher
I'm still getting the 'login' screen.
toypusher
Images: 324
Postby JIML1943 » Tue May 08, 2007 4:30 pm
I don't know why you can't get them i went back and checked ane they are shared to public.Let me get on wifes pc and see if i can open them. From what i see you need to be logged on to yahoo.
JIML1943
Images: 71
Postby toypusher » Tue May 08, 2007 5:20 pm
You don't have to be logged into Yahoo to see my photos that are on Yahoo!! Are you sure that they are shared with everyone??
toypusher
Images: 324
Postby JIML1943 » Tue May 08, 2007 5:45 pm
Public
Anyone can view it at: http://new.photos.yahoo.com/jim_l_1943/albums
kERRY Thisis what it says
JIML1943
Images: 71
Postby toypusher » Tue May 08, 2007 7:15 pm
JIML1943 wrote:Public
OK! It's your 'tinyurl' link that does not work. Here is a new tinyurl http://tinyurl.com/25lvdk
BTW: I just realized that you were my neighbor at the N meets S event!!
toypusher
Images: 324
Postby JIML1943 » Tue May 08, 2007 8:59 pm
Was that your red truck across the street from Barb and i.
were on the left.
JIML1943
Images: 71
