That laminate should be predone if it is to stay on as it should.
I dealt with the same material here in Finland.
We used a huge press to do that with and it should also contain heat to properly adhere. Here is the press. Also it is best to plan ahead and predrill all mounting points. also so that mouldings will cover the areas where the screws would be inserted..
Our Mahogany Veneer was pressed on and the Aluminum was done on a huge Vacuum table. Id say it has both its advantages and disadvantages.
We are working on another way to do the 2nd tear in the future. We,ll see.
I get done with this one and Im taking a long break..
Classic Finn
