1/8" plywood
1/8" plywood
Postby smitty2 » Mon May 14, 2007 4:18 pm
Where can I find 1/8" plywood for the interior ceiling and the roof? The box stores around here don't have the stuff. What about using 1/8" wall paneling?
Thanks
Russ
smitty2
Postby NightCap » Mon May 14, 2007 4:25 pm
I found the plywood that I used at the local plywood shop downtown. 1/8th inch luan did the trick for me. It was a bit cheaper getting it from the source instead of home depot etc.
#1 - 100% Done #2 - 100% Done Thinking about #3
NightCap
Images: 259
Postby Miriam C. » Mon May 14, 2007 4:43 pm
Try the real lumber yards and ask if they can order it. Or find a cabinet shop and see if they can get it for you.
GirRdun :thumbsup:
Postby Sierrajack » Mon May 14, 2007 6:25 pm
Yep, box stores don't usually sell 1/8" anything. Use regular wall paneling and turn it around if you want the real wood look. Inspect carefully, sometimes the back sides are pretty crappy. If you have to bend it around a radius, I suggest wetting it down a might with a sprayer, wait 15 minutes and then shove your guts out. The first one I did cracked so bad and gave me a hernia so I wet down the second one and it snuck right in there.
Sierrajack
Images: 41
Postby smitty2 » Mon May 14, 2007 7:33 pm
I've check with a couple of regular lumber yards,no luck yet. Thought about the back side of wall paneling,but was wondering how it would hold up.
Russ
smitty2
Postby Sierrajack » Mon May 14, 2007 9:09 pm
Russ,
Wall paneling IS Luan - one side has the finish and the backside is bare wood.
Sierrajack
Images: 41
Postby Airspeed » Mon May 14, 2007 11:00 pm
I redid my interior with Luan door skins,they come in 3X7' sheets and bend easily. cost around $6 each. Aaron
Airspeed
Images: 16
Postby grant whipp » Tue May 15, 2007 2:21 am
Not all 1/8" wall paneling is luan-backed ... especially the stuff at the big-box outfits. If it doesn't have real plywood (luan) backing, stay far away from it ... unless you're using it for patterns ...!
CHEERS!
Grant
grant whipp
Teardrop Manufacturer
Images: 117
Postby Ira » Tue May 15, 2007 4:39 am
You want some nice birch and don't mind spending more? Call Boulter in Massachusetts for their bendy birch:
www.boulterplywood.com
They have 1/8" stuff that actually rolls into a TUBE for shipping.
I used their 1/4", which had to be shipped flat, but it was more rigid. Still, NO problem on any of the bends.
You see, for my order, they ran out of the 1/8" I asked for, so they absorbed these monster shipping charges and shipped me 1/4" instead, flat and sandwiched between two pieces of FLAKEBOARD that I was also able to use for my build.
I used the same 1/4 for ceiling and roof.
Here we go again!
Ira
Forum Storyteller
Images: 118
Postby Tim & Lori » Tue May 15, 2007 4:42 am
I see you're in Ohio!! Check with Keim Lumber in Charm Ohio.
They've got a great selection of 1/8" ply both rigid and bendable.
And the good news is they also deliver around most of the state.
1-800-362-6682
Do a search on Google or Yahoo-I think they have a website. They are in the heart of Amish country and the place is huge!! They even opened a restaraunt recently for both customers and the employees. You gotta see it to believe it.
won't be long now....
Tim & Lori
Images: 134
Postby smitty2 » Tue May 15, 2007 5:33 am
Tim&Lori wrote
" I see you're in Ohio!! Check with Keim Lumber in Charm Ohio.
1-800-362-6682"
Charm is a couple of counties east of us. Looks like a weekend trip coming up.
Thanks
Russ
[/quote]
smitty2
Postby b.bodemer » Tue May 15, 2007 12:33 pm
:thumbsup: :thumbsup: Two thumbs up for Keim.
I made a trip there for some of the wood needed and also had a great lunch at one of the local Amish resturants. It was well worth the drive from Cleveland to Charm for the day.
:vroom: ....head to Keim's.
Barb
b.bodemer
Images: 328
