Need ideas for IceBox shelves
Postby Airspeed » Tue May 15, 2007 2:06 pm
I need to install some shelves in my ice box,The ones that were in it are crapola! I restored the IceBox and need some ideas for a shelf to put the block ice on (must hold water to drain through hose in bottom ),shelves for food and stuff. The ice box is 15 3/4" deep by 14 1/2" wide inside.
I am also looking for a timer to turn on a fan once in awhile to circulate the air.
Any ideas would be greatly appreciated!!!!!!! Thanks Aaron
Airspeed
Images: 16
Postby Podunkfla » Tue May 15, 2007 2:29 pm
Airspeed... How about vinyl covered closet shelving? They come with little plastic tips to cover the cut ends too. Just a a thought... ;)
<B>~ Brick
Image...Lots more pix here!
Podunkfla
ol' noodle haid
Images: 5
Postby Ira » Tue May 15, 2007 2:35 pm
Are you gonna use the ice box as pictured? Or instead, with the lid opening up?
Here we go again!
Ira
Forum Storyteller
Images: 118
Postby Airspeed » Tue May 15, 2007 3:47 pm
It will be used as it sits,like a regular fridge. I am even putting a light in it that turns on when open. here it is installed, Thanks, Aaron
Airspeed
Images: 16
Postby fornesto » Tue May 15, 2007 3:54 pm
Cut up some "cooling racks" to fit just right. You know, the things that you put cookies on when you take them off the flat cookie sheets. They make them in aluminum so no rust. The vinyl covered shelving will rust if left in a damp environment. I had them rust in our laundry room just from the humidity.
fornesto
Postby Et Cetera » Tue May 15, 2007 5:28 pm
You might consider checking out some small shelf organizers at Target or Wal*Mart. They're designed to fit in school lockers, so you should be able to find something that should work for the ice box.
I use something like this to gain more counter space at home.
http://www.stacksandstacks.com/html/350 ... t-of-2.htm
Here's an example of something from Target (might be a little big, but you get the idea):
http://www.target.com/gp/detail.html/sr ... B00077JFVQ
http://www.target.com/gp/detail.html/sr ... B0007MHD2E
~Teri
Et Cetera
Images: 28
Postby Airspeed » Sat May 19, 2007 3:32 pm
Thanks all! I will keep my eyes ope for stuff like that! Aaron
Airspeed
Images: 16
Postby George Kraus » Sat May 19, 2007 4:55 pm
An Ice Box normally uses a shallow tray to keep things dry underneath it, how about a plastic storage box from Walmart modified to sit down inside of a wire frame shelf? Then run the hose from the box to the drain.
George
Started on the long road to happiness
George Kraus
Images: 16
Postby Ira » Sun May 20, 2007 8:44 am
Airspeed wrote:It will be used as it sits,like a regular fridge. I am even putting a light in it that turns on when open. here it is installed, Thanks, Aaron
Why do I get depressed every time Aaron posts updated build photos?
Oh, I'm happy for him.
:x
GO! ENJOY THAT PERFECT TD OF YOURS! HAVE A BLAST! DON'T GIVE A THOUGHT TO THE REST OF US CAMPING IN SLUMS!!!
Here we go again!
Ira
Forum Storyteller
Images: 118
Postby Duane King » Mon May 21, 2007 12:08 am
I'm using a Coleman brand steel belted cooler. I discovered that the local restaurant supplier sells clear plastic food service bins with lips on them that hang perfectly on the moulded interior ledge of my cooler. In these bins I will be keeping my ice supply. (Or I may keep ice somewhere else and use the bins to keep food that I don't want to get wet)
You could probably do something similar if you either rigged some kind of rail to the inside of your fridge and hung the bins on them or if you set in one of the metal shelving units that others have suggested and park the bin on top.
Then all you would need to do is provide a drain through this bin. Or take it out and dump it every now and again. That is what I will do..
I like your rig. I hope I never have to park next to it. :cry: :lol:
Duane King
<img src="http://www.mikenchell.com/images/roadhouse.jpg" >
Duane King
Images: 98
