Basicly I need the 1st sheet of 3/4" for my floor. Can I make the floor 2 piece? A 4X8 piece in the sleeping area and a 4X2 piece in the galley? Or go with (2) 4X4 pieces and put the joint in the middle? If I bolt it all down good would it be ok?
George T. wrote:Greetings from Colorado Eric!
Sure you can use 2 pieces for the floor! Just plan on the joints being above a frame member. If you are building a wooden sub-frame, so much the better. Use liquid nails construction adhesive everywhere the plywood contacts the wooden frame and screw the plywood to the frame. It won't leak and it's NOT going anywhere.
George T.
