by Marty » Mon Nov 29, 2004 7:12 pm
Eric,
As a residential building contractor I am very familiar with the Orientated Strand Board (OSB) sheathing material tradenamed as Advantech. The product is a moisture resistant subfloor material. In residential construction the weather elements sometimes play havoc on traditional OSB products. Traditional plywood for residential construction is old technology. Old architects and specifiers are sometimes still specifing it because they haven't had to pay for a delamination claim!!! Advantech has the added positive is that you can go over the top with a variety of floor coverings without having to add another layer of underlayment. Traditional OSB would need a interior grade 1/2" plywood on top of the floor sheathing to be able to install traditional hardwood flooring. With Advantech we could go right over the top.
Advantech as the flooring for the deck of a tear? It would probably work I would prefer to use a treated plywood. Price wise Advantech would be less expensive than a treated plywood.
Hope this helps.
Marty
The four most expensive words in renovation are: "While we're at it..."
