by doug hodder » Mon May 21, 2007 12:07 am
I screwed up on this tear...I have one at the front, over the door, and one at the rear at the galley, the interior is overlain with birch ply, and the exterior is coated out in epoxy, then painted....I don't think it really matters either way, if you have a good joint, if you are doing a woody and making a joint in ply that will be really visible, I'd put it over the door, otherwise, either way is going to be fine. I do build using epoxy as an adheseive as well as a top coat, so that make some structural difference...Doug
