How did you connect your teardrop body to the frame
Screw, bolt, U bolt, put wood above and below the frame, attached frame to the sided and floor to the sides. Drilled holes and tied wet rawhide strips around each bar? That might be worth a poll!! I will make one later.
Ron D.
