Floor anchoring advice.
Postby TomW » Mon May 28, 2007 6:54 pm
What is the prefered method of anchoring the floor frame to the trailer frame?
I have read about using through bolt/counter sinking the bolt head, etc.
Anyone used blind nuts (t-nuts) on top of the frame and then bolted from the bottom?
1/4-20 or 3/8-16?
Trailer frame completed, painted. Now on the the floor.
Thanks
Tom.
TomW
Images: 24
Postby mikeschn » Mon May 28, 2007 6:57 pm
I would go with at least 3/8". Anything smaller than that doesn't have any shear strength to speak of.
As for the style, you pick!
Postby Bigwoods » Mon May 28, 2007 11:08 pm
I used elevator bolts. They are flat on top. I was going to cover them anyway but it worked great. There was a very interesting thread about how may bolts were needed. I think it ran from 4 to 20.
Greg in Northern Minnesota
Bigwoods
Images: 104
Postby Airspeed » Mon May 28, 2007 11:27 pm
I used eight 3/8" carriage bolts with barbed carriage washers to mount mine, I feel pretty confident with it. But I also built my own trailer hitch and feel confident about it as well,( I just learned how to weld so I am either a good welder or just stupid ) Aaron
Airspeed
Images: 16
Postby Miriam C. » Mon May 28, 2007 11:30 pm
I used T-nuts and really like them. I did put some evil smelling black goo in the holes and added a washer then the bolt (3/8th). This can be really messy so some silicone might be better. :lol:
I drilled right through the frame and floor so no question of any mis-match.
Postby mikefowler » Tue May 29, 2007 1:04 am
14 - 3/8 Carriage Bolts W/ Nylock Nuts
It ain't going anywhere.
Aerodynamics are over rated!
I DRIVE A BOX!
Scion XB 2006 - 5 speed Manual
My continuing saga of 'As the TTT is built"
mikefowler
Images: 36
Postby Keith B » Tue May 29, 2007 9:52 am
I have about 8 1/4x20s, grade 8, and about 12 screws going through the floor into the steel.
Keith
"Work and work and do your best! Paint and putty will do the rest!"
Keith B
Postby fornesto » Tue May 29, 2007 1:09 pm
I used 12 3/8" stainless bolts and lock nut setups and construction adhesive all around to prevent and slipping and increase shear adhesion. I then black-gooed the whole thing from the underside, to fill in all the seams.
fornesto
Postby TomW » Wed May 30, 2007 6:42 pm
Thanks for the information. Hopefully in the next couple of days, the floor will be mounted.
Thanks.
Tom.
TomW
Images: 24
Postby Micro469 » Wed May 30, 2007 10:14 pm
I used T-nuts and 3/8" bolts with rubber washers between the trailer and the frame. Then I Epoxyed the top in the trailer. Should keep it dry....
John
Micro469
Images: 382
Postby bledsoe3 » Thu May 31, 2007 2:59 am
I used 10 3/8 carriage bolts with Nyloc nuts. I also welded pieces of angle iron to the inside of the frame and mounted through those instead of drilling holes in the frame.
http://tnttt.com/album_ ... ic_id=1993
bledsoe3
Images: 112
