Opinions wanted
Opinions wanted
Postby csdivine » Tue May 29, 2007 4:10 pm
In building my own window. I have sandwiched a piece of polycarbonate between two pieces of 1/8" plywood. Oak on the inside and birch on the outside.
Rather than try to screw the sandwich together, I'd like to drill completely through it and fasten it with some sort of fastener that looks nice on BOTH sides of the "sandwich".
Does anyone have an idea of what sort of fastener I should look for, other than the regular machine screw and nut or cap nut? I want something decorative on both the inside and outside. AND, something that would be relatively easy to remove if (gods forbid) I ever needed to remove the glass for repair.
-- Chris
Build Diary With Pics
"A man can live on packaged food from here to Judgement Day if he's got enough rosemary."
-- Firefly, Episode One: "Serenity"
csdivine
Postby madjack » Tue May 29, 2007 4:47 pm
...first thought is to use a SS machine(?) bolt and a SS trim washer on the outside and back it with another trim washer and an acorn nut on the inside...an alternative would be same system with a rosette(think mobil home cieling) instead of the trim washer, especially for the inside...just a first thought.....
Postby Classic Finn » Tue May 29, 2007 4:50 pm
I put mine on with just the ol fashion way with a Rubber Seal...
another gentleman that maybe able to assist is Rob48 he,s also got some fancy windows in his...mighty fine build.. he may chime in yet as well.
Im also watching with interest as to how you end up completing yours..
Dont know if its the best way but it was my way.. 8) 8) 8)
Classic Finn ;)
Classic Finn
Midnight Sun Voyager
Images: 146
Postby madjack » Tue May 29, 2007 4:54 pm
...look at E,F,G here; http://www.leevalley.com/hardware/page. ... at=3,41306
look around there site for other ideas...have you thought about as Heikki suggested and use a rubber gasker to install.....
Postby Classic Finn » Tue May 29, 2007 5:00 pm
madjack wrote:...look at E,F,G here; http://www.leevalley.com/hardware/page. ... at=3,41306
I need to git some fresh photos of what it looks like now.. I be liking it.. simple and nice..
Classic Finn ;)
Classic Finn
Images: 146
Postby kirkman » Tue May 29, 2007 6:13 pm
Give these guys a try they have glass trim that might help!
http://www.austinhardware.com/dept.asp?dept%5Fid=8
kirkman
Images: 55
Postby JIML1943 » Tue May 29, 2007 6:35 pm
Some days all you can do is smile and wait for some kind soul to come along and pull your ass out the bind you've gotten yourself into.
Happy camping Jim & Barbara
JIML1943
Images: 71
Postby grant whipp » Tue May 29, 2007 10:06 pm
Yeah! ... what Jim just said (and found) is just what I was thinkin' ... :thumbsup: ....!
CHEERS!
Grant
grant whipp
Teardrop Manufacturer
Images: 117
yeah just call it a
Postby Steve Nikkel » Tue May 29, 2007 11:46 pm
Chicago Screw. Use then all the time in my shoulder holsters (D.ink Slinger is a western action shooter) One word to the wise...a small drop of loc-tite on each before assembly will keep them from working loose.
Steve Nikkel
I'm Draggin-----Draggin the Main once more
With a Peroxide Blonde in a hopped up model Ford.
(Brian Setzer)
Steve Nikkel
Postby Micro469 » Wed May 30, 2007 10:17 pm
Grant Whipp wrote:Yeah! ... what Jim just said (and found) is just what I was thinkin' ... :thumbsup: ....!
CHEERS!
Grant
I vote the same thing.... :thumbsup:
John
Micro469
Images: 382
Postby csdivine » Fri Jun 01, 2007 12:59 pm
THANKS JIM!! That is PRECISELY the type of thing I was hoping to find. Glad I asked here!
Thanks again!
Chris
csdivine
