Eric Adams wrote:Never heard of PL-400. Is it better or the same?
It's the same, just a different label on the tube. I suppose that if you were to take each brand and strength test them, one might prove to be better than the other and maybe not. But it's for certain, any construction adhesive is way better than anything we'll demand from it in teardrop construction. And the stuff is just NOT expensive compared to other glues. You can practically buy a case of it for what Gorilla Glue costs.
TDThinker, I would do more than just the silicon. Silicon does not have ANY adhesive properties to speak of and therefore, you'll be relying on your bolts to hold the floor/sides to the frame. With Liquid Nails (contruction adhesive), you'll not only get adhesion, you'll get sealing as well. The adhesion is good enough that the bolts only need hold as long as it takes for the construction adhesive to cure - about 24 hours. Over a period of time, as you use your teardrop, your bolts will work loose if you use only silicon between the wood and the frame, but the construction adhesive will NEVER come loose. I'd rethink the silicon only idea.
Hey, I gotta tell ya this true story. I had a particular tool box when I was trimming houses and building staircases. I always used construction adhesive to glue step treads down to the risers before nailing them into place. This prevented the step treads from ever squeaking. I was locally famous for building many squeak free stair cases. Anyway, I was slathering on some construction adhesive and a glob of it fell into my tool box. I didn't see it go in or I would have cleaned it out immediately. You can clean up wet const. adhesive with acetone but once it's dry, forget about it. Anyway, then I bumped my tool box with my foot and a wrench slid over into the wet glob of glue. I didn't find it until the next day and by then it was too late. For the next 12 years, that wrench stayed fastened to the bottom of my tool box until the box itself got so old and rickety that I finally threw it out. I believe that, to this day, somewhere in a landfill that wrench is still glued to what's left of that tool box. But all the time I had it, I couldn't get the wrench removed without tearing up the box.
