Jigsaw Blade Question
Postby Classic Finn » Thu May 31, 2007 11:13 am
Im about to skin the Front Tow Box with Aluminum..
And my intention to cut with my Jigsaw to get the proper size from a near full sheet..In my Black n Decker Jigsaw I received a blade that Im not sure if I can use..
It is a normal wood cutting blade.. Will it work or should I go purchase another blade and if so what kind must it be..
Best regards Heikki
Classic Finn
Midnight Sun Voyager
Images: 146
Postby goldcoop » Thu May 31, 2007 11:33 am
Heikki-
Wood cutting blades generally have coarse (few) teeth. Cutting with this type blade will cause a lot of swarf (wavy, jagged edges).
Get yourself a fine (many) toothed Metal cutting blade. Trial cut a piece of scrap to determine best speed...
Coop
goldcoop
Images: 32
Postby Classic Finn » Thu May 31, 2007 11:52 am
goldcoop wrote:Heikki-
Coop
Thank You Coop .. Understood.. On my way for a blade.. Photos to follow.
:D :D :D
Classic Finn
Images: 146
Postby Sierrajack » Thu May 31, 2007 12:18 pm
Heikki,
When in doubt - always use a hatchet!!! Don't forget, to use masking tape around the edges so the jig saw doesn't leave scratches, grooves and other things that make you want to throw something against the wall.
Sierrajack
Images: 41
Postby madjack » Thu May 31, 2007 12:49 pm
Sierrajack wrote:Heikki,
...a very good suggestion indeed...while a new fine toothed blade will work, most AL can be cut/worked with any(almost) woodworking tools...a fine toothed blade may load up with AL cutting, a coarser toothed blade would not load up as bad...the above are just random thoughts...testtesttesttest...YMMV
Postby Classic Finn » Thu May 31, 2007 1:56 pm
:lol: :lol: Sorry Sierrajack this ol boy dont own a hatchet but I do have a collection of good knives.. but I think it would take a looooooooong time to carve out aluminum wit them.. :)
But yes for sure Ive got the tape ready for the area to be cut out..
I,ll practice with the aluminum on the front box... then proceed with the big stuff...this will be a new experince for me... :oops:
Thanks
Classic Finn ;) :thumbsup:
Classic Finn
Images: 146
Postby Classic Finn » Thu May 31, 2007 1:59 pm
Okidoki here is what I went and picked up from my favorite local store
A 3 packer...set of blades..
good for 1.5mm - 3mm aluminum...
They told me to use the low cutting setting on the jigsaw... I guess I,ll find out in a few when I go and play with it.. ;) many of you have cut aluminum or stainless hundreds of times but this ol sailor will be doing his 1st in a few minutes.. gots to go play...
Do I need to use any oil on the metal or not required?
Classic Finn ;)
Classic Finn
Images: 146
Postby GregB » Thu May 31, 2007 2:45 pm
Finnster,
No need to oil up, the alumin(i)um is too thin to build up a lot of heat. BTW, Coop, I thought that swarf was just the shavings, not the edges. Are you referring to kerf?
Greg
I'm not dead, yet. I'm feeling better.
GregB
Images: 108
Postby Classic Finn » Thu May 31, 2007 2:50 pm
GregB wrote:Finnster,
Greg
Okidoki Mr. GregB
Thank You ..
Finnster? :lol: :lol: :lol:
Classic Finn
Images: 146
Postby Sierrajack » Thu May 31, 2007 5:16 pm
Heikki,
Just have good support for the aluminum or you'll be doin' the jitter bug across the shop - wappa, wappa, wappa.
:hammerhead:
Sierrajack
Images: 41
Postby Classic Finn » Thu May 31, 2007 5:46 pm
:hammerhead:
Your a lil late on that ... :lol: :lol: :lol: I felt like shake rattle n roll there a few seconds till I had it properly supported but gee it cuts like butter..
I did the taping as you said ...COOL .. Nice clean run..
I may be old but I learned sumtin new again... :thumbsup: :thumbsup: So the sayin that You cant teach an ol dog new tricks??? sheeeeeeet its not true..I say.. :D :D
I do intend on receiving my Graduation Diploma from the International School of TT and T ... 8) 8) 8)
;) Classic Finn
Classic Finn
Images: 146
Postby Keith B » Fri Jun 01, 2007 4:50 pm
Pending the thickness you have... I've been able to lay aluminum flat on the ground, score w/ a new sheetrock blade and snap it.. nice clean cut... but it needs to be purdy thin stuff.
Keith
"Work and work and do your best! Paint and putty will do the rest!"
Keith B
