Any imformation will be appreciated.
dewayne
Classic Finn wrote:I was also designing the Towbox Cover on mine and I decided to do the following as if I was building another hatch..in miniature style..![]()
I need to cut 1 or 2 more ribs.. the top and bottom is Urpean Oak..
Here in Finland the Battery needs to be securely fastened .. also there are boxes that we can purchase for batteries so that they will be in an enclosed case in total.
Also either with the stainless piano hinge or a marine style hinge..I sat and looked at the towbox for hours as If I was watching Tv..![]()
Here are a few photos of what Im doing..All ply for the outer skin is cut and also the aluminum..
There ya have the Finnish Made Towbox in Progress.![]()
Classic Finn
Nitetimes wrote:Now that's certainly an interesting use for that frame clamp, never thought of that. Hmmm, not sure why not either??![]()
dewayne wrote:Thanks for the imfo guys. I think i'll use the piano hinge with an innertube for a seal.
dewayne![]()
halfdome, Danny wrote:dewayne wrote:Thanks for the imfo guys. I think i'll use the piano hinge with an innertube for a seal.
dewayne![]()
Make sure you screw a strip of aluminum over the inner tube on both sides of the hinge knuckle and them use a utility knife to trim off the excess inner tube. I used the same sealer on it as all my other trim.Danny
Classic Finn wrote:halfdome, Danny wrote:dewayne wrote:Thanks for the imfo guys. I think i'll use the piano hinge with an innertube for a seal.
dewayne![]()
Hmmm Danny a flat strip of Aluminum over the inner both sides of hinge knuckle??![]()
Danny see the plant again on my pics.. its used here as a live fencing..
Classic Finn
critter wrote:Hey All,
DUMB ? Why not just put the rubber runder the hinge?IM so confudded!
