choice of exterior wood?
Postby donkro » Thu Jun 07, 2007 3:22 pm
I have a choice of using 1/4 baltic birch or 3/8 bendable plywood for my exterior. Any opinions on which is best? I'm building the superleggara style so it's not as tight a bend as say a benroy. Because it's 5ft wide I'll have to buy 4x8 sheets and bend then width-wise. Any suggestions are appreciated.
donkro
Postby martha24 » Thu Jun 07, 2007 3:44 pm
I presume you are talking about the roof.
We used 3/8" bendable & it worked great. With bendable you have to make sure it bends the right way. With 5', from what I have seen stocked, the way you need it to bend is not as common. I don't know how easily bendable the 1/4" baltic birch is, though it is good wood. If you could get 1/8" baltic birch & make two layers glued together would be better. That seems harder to find. Our first hatch was made of the two layers of baltic birch & I really liked the wood. My husband trimmed some off with paying attention to grain & only option was using it non cross grain & we had problems because the the hatch sprung.
The 3/8" bendable was very easy to work with, but also seemed a very stable roof.
Different people have used different things.
Martha ;)
Martha ;)
martha24
Images: 237
Re: choice of exterior wood?
Postby Chuck Craven » Thu Jun 07, 2007 5:16 pm
donkro wrote:I have a choice of using 1/4 baltic birch or 3/8 bendable plywood for my exterior. Any opinions on which is best? I'm building the superleggara style so it's not as tight a bend as say a benroy. Because it's 5ft wide I'll have to buy 4x8 sheets and bend then width-wise. Any suggestions are appreciated.
Try this place. www.kmhardwoods.com/
They have 1/8" in 5' by 5'
There is a map in their.
Chuck
Chuck a new td builder
Chuck Craven
Images: 62
Postby SaGR » Thu Jun 07, 2007 6:14 pm
Sweet! :thumbsup: :thumbsup:
Rough idea on the cost per sheet?
Building a small bowtop Vardo
Build thread: http://tinyurl.com/yk4hnmd
Generic Benroy: Sold to FIL/MIL
SaGR
Images: 21
Postby Chuck Craven » Thu Jun 07, 2007 6:17 pm
SaGR wrote:Sweet! :thumbsup: :thumbsup:
Click on #5 plywood, its at the bottom of the page Thickness and price.
Chuck
Chuck Craven
Images: 62
Postby SaGR » Thu Jun 07, 2007 6:34 pm
Oh duh... :embarassed:
SaGR
Images: 21
Postby Wolffarmer » Mon Jun 11, 2007 8:38 pm
I found 5x5 1/8 birch at a local lumber yard and bought them out. They will get more in a few days, long before I need it. But they did look at me funny when I asked about "Bendable plywood". At least I don't think they looked at me funny untill then. It was about $18-19. Will have to look at reciept when I get home. :shock:
Wolffarmer
Images: 309
Postby Chuck Craven » Mon Jun 11, 2007 9:29 pm
Donkro and SaGR
You can also get ¾” ext. A ,C grade fur plywood in 5' X 10' from Alpine Plywood here in Milwaukee if you don’t mind the drive. Both are just off I94.
http://www.alpineplywood.com/stocksheet ... ftwood.pdf
Chuck
Chuck Craven
Images: 62
