Tire fender/body clearance ???
Postby kirkman » Sat Jun 09, 2007 1:58 pm
I have my floor done and I have 2 1/2 inches of tire clearance from the floor. Do you think that is enough or do I need more? I am building a 5x8 benroy out of 1/2 b-c ply wood. The TS trailer is rated for 1700 plus pounds. HELP!
Thanks! :?
Jason
kirkman
Images: 55
Postby steve wolverton » Sat Jun 09, 2007 2:05 pm
You could always put bump stops on the trailer so that it would not be possible for the springs to compress more than the 2.5".
�veni, vidi, vici.�
steve wolverton
Images: 11
Postby kirkman » Sat Jun 09, 2007 7:44 pm
Not a bad idea Steve. :thumbsup:
If it looks like like it wont need any more travel than that I might just give that a try. Any idea where I can find them?
:thinking:
kirkman
Images: 55
Re: Tire fender/body clearance ???
Postby toypusher » Sat Jun 09, 2007 7:49 pm
kirkman wrote:I have my floor done and I have 2 1/2 inches of tire clearance from the floor. Do you think that is enough or do I need more? I am building a 5x8 benroy out of 1/2 b-c ply wood. The TS trailer is rated for 1700 plus pounds. HELP!
Thanks! :?
Jason
I would not think that you would need more clearance. My HF 1175 rated trailer has about 2 1/2" travel and does not seem to hit except when I hit a deep pothole very hard ONCE! That is the clearance also that was between the top of tire and the stock fenders.
toypusher
Images: 324
Postby steve wolverton » Sat Jun 09, 2007 7:50 pm
kirkman wrote:Any idea where I can find them?
I would make my own. You could always swing by a junkyard for the rubber piece. If you want to sling some cash...
http://www.autoanything.com/suspension-systems/61A2640A0A0.aspx?kc=CJ1485&PID=1205240
I don't have any on mine and I have 2.25" of clearance from the tire to the plywood floor.
�veni, vidi, vici.�
steve wolverton
Images: 11
Postby kirkman » Sat Jun 09, 2007 8:06 pm
Thanks guys!
Steve....man those things are pricey!!!! I think I will build my own out of a old truck tire or something. that is a lot of $$$ for something so small. Thanks though!
kirkman
Images: 55
Postby cdcofer » Sun Jun 10, 2007 2:06 am
Yes, those are expensive. It's because they're full sets for a truck. You only need a pair of little bump stops. I used these http://store.summitracing.com/partdetai ... toview=sku Only $8.69.
Dean, Elizabeth and Race Cofer
cdcofer
Images: 9
