ninerhb wrote:The reason the manufacturer recommended an air gap is because you're using foil-faced insulation. Having an air gap in front of the foil allows it to reflect radiant heat back into a space, where it can then leak back out through the trailer wall. Having a foil barrier trapped against the wall will reduce it's ability to add insulation value. For something like a roof, this is pretty important. For the tear, it's probably not worth it, since you get structural benefit from sandwiching the insulation tightly.
Henry
You beat me to it. It is the foil that leads to the recomendation for the air-gap, just as you said.
Putting this stuff in the TD, you'll loose most of the benefits of the foil, but the foam inside will still do it's job.
I don't know how much of a gain in R-rating one gets by thin sheets of insulation vs. one layer of 3/4 plywood, anyway. It probably does more for weight savings than actual insulating value.
If you camp a lot in the winter, the most important insulation is in the floor. If you camp a lot in the summer, your roof insulation will be more important.
CD
