Undercoating the floor
Postby SaGR » Wed Jun 13, 2007 7:17 am
Has anyone covered their bottom (the floor of the trailer you bunch of wise guys! :lol: ) like this?
I was wondering about covering the underside of the wooden floor with sheet metal and then coating that in Herculiner (http://www.herculiner.com/).
I'm wondering if that would be a more durable undercoating than just the roofing tar. I'm thinking it'd only add a few pounds to the overall weight.
Thoughts?
Building a small bowtop Vardo
Build thread: http://tinyurl.com/yk4hnmd
Generic Benroy: Sold to FIL/MIL
SaGR
Images: 21
Postby Arne » Wed Jun 13, 2007 12:14 pm
use roof coating. $7/gallon, one can should do it, throw away the brush... you're done.
www.freewebs.com/aero-1
Arne
Mr. Subject Line
Images: 96
Postby dovaka » Wed Jun 13, 2007 12:36 pm
i plan on using something similar for my frame but im just going to use a standard wood sealer for the wood bottom
dovaka
Images: 6
Postby madjack » Wed Jun 13, 2007 12:37 pm
...do what Arne sez...bestest/cheapest method...if you want to use the bedliner, spray it directly on the wood, the sheetmetal pan, unless you are real lucky will become a trap to hold water against the wood and severely intorducie/promote rot in the floor..........
Postby KA » Wed Jun 13, 2007 7:33 pm
Does roof tar smell when the weather warms up? Or, does it get sticky and drip? I know a lot of people use it and I can't recall reading about any problems with it. Just double-checking.
Kris :thinking:
KA
Images: 9
Postby madjack » Wed Jun 13, 2007 8:04 pm
Kris, what you are actually looking for is a product called "asphalt emulsion"...it is thinner than regular roofing tar and doesn't have the fibers init...we use about 6 coats(thinned and sprayed) of MinWax ClearShield...an outdoor rated polyurethane...instead of the emulsion....
Postby KA » Wed Jun 13, 2007 8:28 pm
Thanks, Madjack. :)
Kris
KA
Images: 9
Postby Airspeed » Wed Jun 13, 2007 8:56 pm
I dont know if anyone other than me has tried the spray on bedliner from NAPA, I used it on my frame,inside my tounge box,inside my feners and under the floor, It took two cans to spray the underside of my floor and cost about $12 a can. It sprays on very nice and leaves a thick rubber textured suface,it never totaly hardens meaning it has a rubbery feel to it after it cures but it wont smear like roofing products and adheres very well. They sell it in a gallon can but I couldnt find my bedliner gun.
I think this type of stuff will work better than anything unless you want to spend the money for Rhino liner or similar.
I sprayed the same stuff in my pickup bed about six years ago and its still there. The stuff I used is "Martin Senour Premium Rubber Undercoating 4500" It even filled the voids in the plywood so water cant get in.
Aaron
Airspeed
Images: 16
Postby KA » Wed Jun 13, 2007 11:09 pm
Thanks for the info, Aaron and Dovaka. It is nice to hear about different successful options.
Kris :)
KA
Images: 9
Postby Roly Nelson » Thu Jun 14, 2007 1:35 am
My nephew has a Line-X booth and sprayed my tear and tongue box bottom as well as the wooden fender wells. That was 4 years ago and it's holding up well. Added more weight than I wanted, but I couldn't beat the price.........zero? My next tear has a simple coat of asphalt emulsion, roofing patch material and works just a well. but cost more......a few bucks..
Roly ~~ :)
Roly Nelson
L'il Ol' Woody Builder
Postby Classic Finn » Thu Jun 14, 2007 1:54 am
I thought Id chime in on the coating thread.. here I used the following ply named Wisa Transport..or Wisa Multifloor. no need for the extra painted materials for surface protection.
Im just not sure its available there, however maybe bigger ply dealers may have the product..as Finland does export this ply to the States .
The edges are also pretreated..
Also I noticed some of the Caravans use the same ..this same is used for vans, utility trailers, truck trailers and so on.. multiple uses..here is what it looks like.
Classic Finn ;)
Classic Finn
Midnight Sun Voyager
Images: 146
Postby Airspeed » Thu Jun 14, 2007 7:08 am
That is some nice looking plywood, I will have to look for some of that for another project I am doing. Is it some kind of rubber laminate? What does it cost? Thanks! Aaron
Airspeed
Images: 16
Postby Classic Finn » Thu Jun 14, 2007 7:51 am
Airspeed wrote:That is some nice looking plywood, I will have to look for some of that for another project I am doing. Is it some kind of rubber laminate? What does it cost? Thanks! Aaron
Hi Aaron
here is the website in English, hope it helps you some. Here in Finland I paid 35 euro for it or its 46.00 USD.
http://w3.upm-kymmene.com/upm/internet/ ... menu,0,0,0
Classic Finn
Classic Finn
Images: 146
Postby angib » Thu Jun 14, 2007 9:36 am
As Heikki says, this one is the standard floor for utility and work trailers in Yurp:
They're phenolic layers on the outside and they're tough enough to withstand serious abuse.
I've not seen the fancier 'treadplate' and 'raindrop' versions before.
Andrew
angib
5000 Club
5000 Club
Images: 231
Postby KA » Thu Jun 14, 2007 10:36 am
Heikke, that flooring is really neat-looking. I haven't seen any yet in our area but I bet it would work beautifully on a teardrop.
Thanks for the idea.
Kris :)
KA
Images: 9
