Doors and latches
Doors and latches
Postby Roddy Riggs » Thu Jun 14, 2007 6:46 pm
OK, got my doors hung, used counter top edging around the door opening and T molding around the edges of the doors. The interior of the doors lacks about 1/4" from flushing up with the interior walls (due to the trim). How do you guys compensate for this? Should I just notch out part of the opening so that the latch bolt will catch?
I bought my latches and handles from Austin Hdw. The handles have a shoulder on them, underneath the mounting plate approx. 7/8" diameter. When drilling the hole in the door to insert the square handle should I drill a hole for the shaft, about 3/8" diam. and then drill the 7/8" diameter hole to countersink the handles shoulder or, do you guys just drill a 7/8" hole all the way through the door?
I've been to three county fairs and a goat roping, but I ain't never seen anything like this!
Roddy Riggs
Re: Doors and latches
Postby bledsoe3 » Fri Jun 15, 2007 1:19 am
Roddy Riggs wrote:OK, got my doors hung, used counter top edging around the door opening and T molding around the edges of the doors. The interior of the doors lacks about 1/4" from flushing up with the interior walls (due to the trim). How do you guys compensate for this? Should I just notch out part of the opening so that the latch bolt will catch?
I drilled the smaller hole and then the larger just deep enough for the shoulder. For the latch I just shimmed it out far enough for it to latch.
bledsoe3
Images: 112
