Page 1 of 1
Roof scarf Joint ?
PostPosted: Sat Jun 16, 2007 3:39 pm
by kirkman
What do you use at the scarf joint on the out side to keep the roof from leaking. Epoxy and glass tape or....?
Thanks !
Jason
PostPosted: Sun Jun 17, 2007 8:05 pm
by NightCap
I used epoxy and glass both and a bunch of enamel paint.
PostPosted: Sun Jun 17, 2007 8:21 pm
by Geron
PL Urethane to stick it together (and waterproof)
CPES
epoxy filler
Lots of epoxy -- 3 coats
Marine Topside paint from West Marine -- Their brand.
That's it.
Didn't think glass was necessary 'cause, (I think) it's main purpose is to strengthen the joint and that joint is strong enough on it's own.
g
PostPosted: Sun Jun 17, 2007 9:21 pm
by NightCap
Geron wrote:PL Urethane to stick it together (and waterproof)
g
I think I would agree. I put some fiberglass tape on all my joints and seams that were on top of my tear. If I had it to do again I would have left the fiber glass off the edge joints at least cause it does not sand or look too good. I probably could have done it better, but I think I could have gotten a much smoother pro look by using just the epoxy and paint.
PostPosted: Mon Jun 18, 2007 10:52 am
by kirkman
Thanks Guys. I ended up Using west systems 105-a epoxy and glass tape. Just to make sure nothing came apart or leaked!
PostPosted: Mon Jun 18, 2007 10:56 am
by steve wolverton
kirkman wrote:Thanks Guys. I ended up Using west systems 105-a epoxy and glass tape. Just to make sure nothing came apart or leaked!
:thumbsup: That's a good way to handle it.
PostPosted: Mon Jun 18, 2007 2:20 pm
by kirkman
Night cap.... You could have feathered it in( like you would with bondo) with resin mixed with airocell thickener.
PostPosted: Mon Jun 18, 2007 5:39 pm
by NightCap
kirkman wrote:Night cap.... You could have feathered it in( like you would with bondo) with resin mixed with airocell thickener.
Yeah, I should have. I wonder if it is too late with the several coats of enamel I have on there now.
