Page 1 of 1
Bracket for table top
PostPosted: Fri Jun 22, 2007 5:44 am
by galen neibarger
Hello All,
I want to come up with a bracket to hold a table top at the end of my Tear Drop counter. Table will be about 25" by 35" with one or two legs. I have seen photos of others mounted on the sides. Can this be bought at a RV supply or does it need to be custom made.
Thanks for your help,
Galen
PostPosted: Fri Jun 22, 2007 6:12 am
by Rickxr2
One type I've seen used a lot is two pieces of aluminum, one mounted to the wall, the other to the table. RV suppliers carry that item.
Rick
http://www.ervdealerservices.com/display.aspx?catid=59&productid=6637
PostPosted: Fri Jun 22, 2007 6:17 am
by bobhenry
http://www.harborfreight.com/cpi/ctaf/d ... mber=93223
Good ol' Harbor freight "The teardroppers friend"
PostPosted: Wed Jun 27, 2007 7:37 am
by diverguy
i made mine myself from two pieces of 3/8 alum angle. one piece mounted to the camper and one mounted to the the table. two hole and some 1/4 pins. here are a couple of photos.
PostPosted: Wed Jun 27, 2007 9:38 am
by Tear Les
Nice setup Diverguy :thumbsup:
You can find the premade supports at www.go-rv.com ... look here. The 30" section (2 pieces) is $6.39 retail. One side fastens to the trailer the other to the table end and then they nest together; pretty neat setup.
