Aaron Coffee wrote:Planning on my next build to be based on the generic Benroy plans. Did I read the plans right, it is 5 wide, 4 tall and 8 long? If so is there any reason why I couldn't stretch it to 10 foot long?
Thanks
Aaron Coffee wrote:I guess the biggest question if I just build on the frame, how do I get a good strong joint between the floor and wall?
mikeschn wrote:Can you expand on that more? Are you thinking about bolting a piece of plywood to the chassis, and bolting the walls to the chassis? A bunch of self taping screws would hold the walls to the chassis really well, but how would you seal the joint between the walls and the floor?
Mike...Aaron Coffee wrote:I guess the biggest question if I just build on the frame, how do I get a good strong joint between the floor and wall?
Aaron Coffee wrote:.... measured a twin mattress and it is 39 inchs wide by 6 foot 3 inchs long. So it looks like that will be the dimensions.
