toypusher wrote:You could try something like this:
Of course all of the material thicknesses could be changed. I think that I would use 1/4" for the outside skin, if I were building it now. I probably would not use the bolts either, just use screws. This is an old drawing, but gets the idea across, I think.
SaGR wrote:Floor is done, still need to insulate and put on the roofing cement.
I need to build up 1/4", so I might go ahead and just sandwich the floor. If I go this route I'd only need to tar the bottom ply correct?
I had to laugh - I was so careful to make sure the floor was square. Wouldn't you know it, the trailer isn't! As a good friend would say "Ain't 'dat a b!7ch!"
www gallery updated. More tomorrow!
Micro469 wrote:You sure do look a lot like your Avatar...
SaGR wrote:Oh yeah, almost forgot - that pocket screw jig rocks!!! Holy cow did that make quick work of the frame!
madjack wrote:now all ya gotta do is keep the SaGR lined out and y'all will be campin' before ya know it and one last thing...sometimes the quest is the best part........
