Window Installation
Window Installation
Postby Hudsonite » Tue Jul 03, 2007 5:58 am
Well, I feel really stupid, but even after reading the two threads on window installation I still can't figure out how to install them. I understand how the screws go through the clamp ring into the "race" or whatever that channel is around the window. But I can't figure out how the window is held fast to the camper. Are there any pictures available? Does anyone have a shot of their installed window and/or the clamp ring? I guess with these things I'm a visual learner. Thanks in advance for any help you can give.
Hudsonite
Postby Geron » Tue Jul 03, 2007 6:01 am
What kinda winder you puttin' in???
Pics??
g
Geron
Images: 173
Postby 48Rob » Tue Jul 03, 2007 6:49 am
Good morning,
The window is set in the opening from the outside.
The ring is set in the opening on the inside.
The screws serve to pull the two halves together and thus "clamp" the widow tight against the side of the trailer.
Rob
48Rob
Postby Hudsonite » Tue Jul 03, 2007 6:53 am
Ahhhh, that makes sense, Rob. Thanks.
G... they're 14x24 windows I got from Grant at Lil Bear. Very nice windows! I can't wait to get them in. I'll post pics asap.
Thanks again!
Hudsonite
Postby madjack » Tue Jul 03, 2007 11:40 am
48Rob wrote:Good morning,
Rob
...just don't forget to seal the outside or you will get REAL wet :lol: ...if you use the clamp ring, putty tape is probably best for sealing...
Postby Hudsonite » Thu Jul 05, 2007 4:29 am
Thanks, Madjack. Can I get the putty tape at any hardware store, or do I have to go to a RV center?
Hudsonite
Postby madjack » Thu Jul 05, 2007 7:21 am
I know my local ACE carries it...as to your local hardware ??? check it and see click to see some
Postby grant whipp » Tue Jul 10, 2007 9:14 pm
madjack wrote:...just don't forget to seal the outside or you will get REAL wet :lol: ...if you use the clamp ring, putty tape is probably best for sealing...
Unless it fell off in shipping, my Radius-corner Windows come with a closed-cell foam gasket already attached to the window frame/flange ... no extra sealant required (unless ya did a little "oopppsss" with the sabre-saw while cutting out the openings ... :lol: ... :lol: ...!)
CHEERS!
Grant
grant whipp
Teardrop Manufacturer
Images: 117
Postby Kankujoe » Tue Jul 10, 2007 9:37 pm
I used putty tape when installing my windows. I put the putty tape on the underside of the window flange then I secured the flange to my trailer walls with screws every 6" or so. On the inside I used silicone caulk to fill in the gaps around the windows.
No leaks so far. Been through some pretty good down pours and also power washed the trailer 3 times... water tight so far.
If your windows have a rigid flange... go with the putty tape. I bought mine at an RV shop.
Joe
Ad-ven-ture: 1. an undertaking involving risk, unforeseeable danger, or unexpected excitement. 2. an exciting or remarkable experience. Trav-el-er: 1. one who seeks to experience their world. 2. one who seeks to be immersed in other cultures.
Kankujoe
Adventure Traveler
Images: 19
