Thanks~!
Jason
Kens wrote:I just made one . Mine is 4" white PVC 45" long U shaped. Holds exactly 5 gallons. I copied Madjacks. I had to put in a 3/8" check valve to keep the water from flowing back to the tank.
Isn't that white PVC like....Sewer pipe??????
Lots of houses are plumbed with itDee Bee wrote:OK Here is a question for those of you in the know:
Does PVC gas off VOCs (Voiltile Organic Compounds)? In other words is PVC really safe for drinking water?
Micro469 wrote:Nobody seems to use the black drain pipe... Is it ABS?... I wonder why>>>>
Dee Bee
Dan Imming wrote:FWIW: I've had (and used) one of these Valterra water tanks in my trailer for three years.
"VALTERRA Water Tank 6 Gallon
ABS plastic water tanks are made from lightweight, high-grade plastic polymers. ABS is tasteless, odorless, non-toxic, and completely algae-free. Fittings can be installed anywhere on the tank with ABS glue; three 3/8" FPT inserts molded on each end. 6 gallon tank measures 8" X 16" X 12". Price: $37.34
Except for the third eye I've begun to grow in my forehead, everything seems normal --- all evidence above to the contrary notwithstanding.
Users browsing this forum: Bing [Bot] and 9 guests
