paint question
paint question
Postby will guthrie » Tue Aug 14, 2007 9:08 pm
I've got the holes and seams of the widget mostly filled and I'm prepping for sealer and paint (researching rustoleum marine poly and interlux brightside if I can afford it) and I have what may be a dumb question. I'm wondering if I should install the windows and roof vent before painting or do it after. All along it seemed to make most sense to paint first and avoid masking and so forth but now am wondering how well butyl tape or the sort will stick and seal against marine paint. thanks
will guthrie
Postby doug hodder » Tue Aug 14, 2007 9:16 pm
Will, I'd paint first and assemble later...lots less paint slop and much cleaner lines, the butyl tape will be fine...a good repaint on a car is done that way. Just my opinion...Doug
Postby apratt » Tue Aug 14, 2007 10:12 pm
Ditto what Doug said. It is easier that way too. Just be carefull when you are putting it together and not to stratch the paint.
Arthur,
ASL spoken here
apratt
Images: 16
paint tip
Postby starleen2 » Tue Aug 14, 2007 10:12 pm
I would paint first, then make your cuts. You can always retouch. I have applied the butyl tape after the paint and it adheres well. However, I found that silicone based chalks do not adhere well to enamel paint after the surface had been painted– and I thought silicone stuck to everything. Remember to get a good quality paint – I know good quality paint is expensive, however you get what you pay for – better solvents, pigments and carriers. It really makes a difference and sometimes the cost between good and best is about $10.00 – 15.00 difference.
starleen2
5th Teardrop Club
Postby Podunkfla » Tue Aug 14, 2007 10:48 pm
I'd avoid silicone like the plague... There are lots better products now. Plus most paints and silicone hate each other... ask any bodyman!
<B>~ Brick
Image...Lots more pix here!
Podunkfla
ol' noodle haid
Images: 5
Postby apratt » Tue Aug 14, 2007 11:03 pm
Brick, you are so right. I absolutly hate that stuff. I would charge the custumer extra when they use it on a windsheild, trying to fix a leak. :thumbdown:
Arthur,
ASL spoken here
apratt
Images: 16
Postby will guthrie » Thu Aug 16, 2007 9:09 am
thanks for the replies. the holes for the windows and vent are already cut out and it sure does seem easier not to have to cut in paint around the installed windows. the fun continues.
will guthrie
Postby Arne » Thu Aug 16, 2007 9:43 am
If not silicone, what is good to use around windows, in case they need to be removed?
ditto for the hatch hinge....
www.freewebs.com/aero-1
Arne
Mr. Subject Line
Images: 96
Postby Podunkfla » Thu Aug 16, 2007 10:55 am
Arne wrote:If not silicone, what is good to use around windows, in case they need to be removed?
Butyl tape, PL Urethane caulk or Sikaflex caulk are all good sealants for outside stuff.
<B>~ Brick
Podunkfla
ol' noodle haid
Images: 5
Postby MrBuzz » Fri Aug 17, 2007 11:54 am
I agree, paint hates silicone...don't even have it in the garage if you are going to paint...enamel or latex!
I found a product called "siliconized latex" at the home improvement store. It wasn't expensive. The label specifically said "paintable" it hardens about like 100% silicon, very tough and flexible, can even use it quite thick to fill some spots. But it doesn't put down that slick film like silicone and paint sticks to it with no problems.
Generic Benroy - built 2007, 4X8, 1175 HF trailer, Structoglass roof and headliner, 12v and 110v electrics with Schumacher charger.
MrBuzz
Images: 77
