to seal or not to seal, that is the question
Postby Mini Renegade » Sat Aug 18, 2007 11:16 am
SORRY IF THIS HAS BEEN ASKED A THOUSAND TIMES BEFORE oops sorry left caps lock on!
is it wise to treat the inside of the roof skin before fitting? I don`t want it to interfear with the glue/ sealant. I am planning on bonding the skin on using the hot mastic used for bonding car body panels and windscreens into place. any help is much appreciated, cheers. rgds Paul
If evvr tha dus owt fr nowt, allus do it fr thissen
Mini Renegade
Re: to seal or not to seal, that is the question
Postby Miriam C. » Sat Aug 18, 2007 3:05 pm
Mini Renegade wrote:SORRY IF THIS HAS BEEN ASKED A THOUSAND TIMES BEFORE oops sorry left caps lock on!
I wouldn't but that is just my personal thing. 8)
Postby doug hodder » Sat Aug 18, 2007 4:13 pm
Paul, I don't seal the roof like you are talking about, but I also don't use the glue that you are planning on using...If in doubt...do a test to see how well it adheres to a sealed piece of material compared to a non sealed piece. Then decide. Some people seal it up, some don't, however I haven't heard of a situation where someone said that they wish they had sealed it up. I sort of think that if it is sealed, and there is a leak, it is entirely possible that the water could travel to some other spot then appear, and it may show several feet away from the original leak. I know that sounds pretty far fetched, but it justifies my not sealing it up... ;) Doug
Postby jplock » Sat Aug 18, 2007 4:41 pm
I finished the insides of walls and roof with spar varnish to slow the progression of rot should there be any slow leaks. If you notice in the lower picture I left all the spots where where panel adhesive would be applied for glueing free of varnish. This would give the best adhesion. This what my father in law did when building his wooden airplane.
Keep smiling!
jplock
Images: 233
Postby Miriam C. » Sat Aug 18, 2007 8:41 pm
Let me correct---I didn't seal the inside of the roof. I did seal both sides of the ceiling. I did this after the spars were glued down as I put my ceiling down first then the spars, then the roof.
Postby Podunkfla » Sat Aug 18, 2007 9:09 pm
I've used PL Urethane sealant to glue metal panels to cars, galvanized roof flashing and even glass to painted wood. If the sealant you are talking about is similar? It will probably work fine. I am not familiar with the sealant you mentioned?
<B>~ Brick
Image...Lots more pix here!
Podunkfla
ol' noodle haid
Images: 5
Postby Mini Renegade » Tue Aug 21, 2007 2:19 pm
cheers guys, will try aa test piece, the glue i have has to be heated in the oven for a hour before applying using a sealant gun. I didn`t want any problems with condensation between the two skins and the insulation.
Mini Renegade
