Gringo Loco wrote:Hi all, I am about to start cutting my wall profile and wanted to know the easiest way to cut out the door. I am using 1/2 for my walls and the profile is like Joanne's Desert Dawg.
Thanx
Joanne wrote:Gringo Loco wrote:Hi all, I am about to start cutting my wall profile and wanted to know the easiest way to cut out the door. I am using 1/2 for my walls and the profile is like Joanne's Desert Dawg.
Thanx
Hi Chris,
I used a circular saw and carefully did a plunge cut on each angle. It's a bit nerve wracking if you intend to use the cutout as the actual door. None the less, as Chaotica suggested, a bit of care and it will work just fine.
Joanne
P.S. - nice choice of profile!
dhazard wrote:Am I the only one that used a router?
