Who spliced 2-3 types of plywood together?
I am going to have to splice 2 pieces together to make my sides and seem to remember that someone had done this on a teardrop but I can't remember who. I need to see some pics.
or t n ttt for short (tnttt.com)
https://www.tnttt.com/
Steve Frederick wrote:If you are covering the Tear, just butt-join with a biscuit joiner, or you could half-lap. My two choices, if the ply is thick enough..1/2" or more. Or you could make the joint in thinner ply, over a framing member. If you want to go with something like what I did on the 'Diners, Check out my site. I did Mike's panels with a saber-saw, Mine, after a little research, with the router...my favorite tool!!![]()
Would it be ok to biscuit-join the 2 pieces together using Liquid nails as a glue between the 2 pieces?
SteveH wrote:Would it be ok to biscuit-join the 2 pieces together using Liquid nails as a glue between the 2 pieces?
IMHO, if I were going to join two pieces of plywood with biscuits, I'd use epoxy glue. Again, just my opinion.
<snip>
A half lap with the thickness you're using would be a good choice too. Try turning the wood so that the face grain runs up/down on the panel. I spliced three sections to get a 11-foot panel for the stripper. Long grain blends the joint away better than an end grain joint.
</snip>
Steve Frederick wrote:Joanne,
Check out my build journal for the stripper. The process is simple. Layout a line about 4 times the thickness of the material, 3" for 3/4" ply. for example. Cut away 1/2 the thickness of the ply, a little at a time, maybe 1/4" each pass, until you get to the fence, clamped to that line. On the back of the mating piece, do the same process. Voila!! Half lap!
If you see any waiver or gap in the joint, you can remove it by laying the pieces together, as you would glue them up, but a little less thean the width of your bit, apart. Say the bit is a 1/2" bit, then space the sheets a bit, maybe 1/8", less than the bit diameter.
Place a fence in a position that makes a cut that will hit both pieces at the same time. The resulting cut will remove just a bit from BOTH sheets, and following the same fence, will be an exact match!
Confused, Check out the journal, A picture is worth a thousand words. <snip>
