As a reminder, the SlumberMAX uses a variety of woods, and for the design...I used steam bent ash, and filled in with individual strips that were scribed to fit...
For side two, I've already applied the border, and rounded off the bottom pieces. To construct the border, I simply cut and glued the 1/4 inch ash boards, routed off the outside and then routed the interior using a router guide.
The first steam bent piece of ash is started by transferring measurements from the first side and setting up a smooth curve. I'll be using 4 - 1/4 inch strips for the upper ash piece. Notice that except for the lowest holder, all of the brackets are on the inside of the final curve.
You just can't bend wood without a fancy steamer consisting of a piece of discarded downspout, a Coleman stove and a teapot. Our "Red Green" guy would be proud to own this setup!!! I ususally steam the strips for about 15 minutes per 1/4 inch of width. If you can find wood that isn't kiln dried...it will bend better.
Here are the first steam bent strips in place. Once you take your hot strips from the steamer, you only have minutes to get them in place before they cool. So work quickly and have your clamps set up. The little brackets are pieces of one inch dowel with a hole in the middle and one side knocked flat with a chisel. The flat side gives me something to clamp to if I need to draw the strips tight. The screw drilled into the 1/4 inch ply side holes the dowel in place. I'll let this dry overnight, glue it up, and bend the lower half in the morning.
