I wouldn't space the floor up off the frame to clear the bolt heads - I would bore holes in the floor where the bolt heads are and sit the floor directly on the frame. When you're done, you can fill the holes with epoxy so the bolt head is encapsulated and the floor is smooth and level wherever the bolts are - That would allow you to tighten the nuts from underneaath, though with nylon locking nuts on them, they shouldn't come loose anywaySam I am wrote:One more point: If you use a bolt together frame, you will have bolt heads sticking out from the frame rails, so the walls cannot be screwed fast to the rails unless you put some spacers on the rails to let the walls clear the bolt heads. You would have to leave enough room near each bolt to get an open end wrench on the head to hold it while you turn the nut in case one worked loose
