by eamarquardt » Wed Sep 19, 2007 10:59 am
Ha! I think we're more on the same page than we'd like to admit. I have thought about the wiring and agree that it should be run in conduit of some sort so you can change or replace in the future. I am thinking of using the poly tubing (like they use to hook up icemakers on refrigerators). I also plan on using LED lighting so the wiring can be light gauge (read small and easy to pull through the poly tubing). You can blow dental floss through the tubing with compressed air, and then use it to pull a messenger or the wire depending on the clearances. I've used this technique to repair the power lines for my tig welder (about a 12 gauge wire in 1/4 vinyl tubing that carries 300 amps (yes 300) because the whole thing is water cooled).
Hope your knee gets better, but according to the 250 doctors I've been to not much hope for me (unless part of the brain dies, not a cheery thought). I have been to Pittsburgh three times, not a big deal to some, but when you're from So.Cal. it's a long trip (particularly when they've bored a hole in the thickest part of your overly thick skull to expose the cranial nerves where they enter the brain). Although the brain has no pain nerves, the bone and tissue they destoy to enter the brain do, it hurt!
I've posted (or will post haste) a few more pictures of my shop and some of the things I've built. Of particular interest to those that like to wire might be the single to three phase converter I built for my milling machine (for those that like to wire). The only thing originally present in the original set up are the two large contactors in the middle of the top box. the rest of the relays, transfromer, capacitors, and idler motor were added to produce a close approximation of three phase so I can run my lathe and mill.
Have a nice day,
Gus
