Hey folks,
I was looking for covering alternatives and found this place locally.
Amerimax makes lots of different laminated building materials that can be used for RV construction.
http://www.amerimaxbp.com/documents/lam ... oducts.pdf
http://www.amerimaxbp.com/documents/Sta ... ochure.pdf
StarBrite, available in popular standard colors like white, black, and champagne. Custom paint matching is also available upon request.
StarBrite is one of the newest and fastest growing trends in the RV industry. StarBrite is made of a light gauge polished aluminum with an embossed tread plate finish to replicate that of heavy gauge steel tread plate at a fraction of the cost. StarBrite is a very cost-effective alternative whose uses are limitless: interior RV decor, rockguards, loading ramps. These are just a few of the most common applications. StarBrite can be used for virtually any project requiring traditional tread plate solutions because it has some very unique features that simply can't be matched by its antiquated predecessor:
* Manufacturing Flexibility
Easy handling and installation
Tolerates bends up to 90 degrees
* Custom Sizes Available
Reduces Scrap
Helps ease installation process
* Lightweight
Minimum of 35% lighter than tread plate
More cost-efficient than heavier gauge tread plate
* Removable PVC Premask
Protects high polished appearance
