Sealing plywood with fiberglass resin
Postby greglaw » Wed Oct 03, 2007 7:07 am
Has anyone used fiberglass resin to seal the plywood and then painted over it? I was going to try this on mine but wanted to check and see if anyone had done it and how it was holding up to the elements. I was going to paint it with automotive PPG. I would like to color match it to my SUV with a retro Z style paint job.
Thanks
Greg~
greglaw
Images: 65
Postby doug hodder » Wed Oct 03, 2007 9:24 am
that's how I do mine...just make sure that any framing like on a woody or the outer perimeter trim as on this one, is sealed really well with epoxy on the edges. And when doing this type of finish, you really need to get the epoxy down nice and smooth or all the uneven spots show. The paint and clear won't hide anything. Doug
Postby Arne » Wed Oct 03, 2007 10:51 am
CPES should work for this... call rot doc and check with them.
www.freewebs.com/aero-1
Arne
Mr. Subject Line
Images: 96
Postby Alphacarina » Wed Oct 03, 2007 12:00 pm
I've used epoxy resin to seal plywood many times - A plywood boat is essentially epoxy resin and wood fibers, primed and painted
Polyester resin sets up too fast to penetrate deeply enough into the wood, so it's seldom used in conjunction with ply in the boatbuilding world
Don
Alphacarina
Postby GPW » Thu Oct 04, 2007 6:25 am
We use an old airplane trick... 75% thinner and 25% polyurethane.... generously slobbered on , soaks in and waterproofs the ply and wood ...any finish seems to go well over it ...Cheap too and not so smelly...it will even waterproof cardboard...
Postby greglaw » Thu Oct 04, 2007 7:01 am
Thanks for the responses folks.
I decided that I would go with the FG resin as I have experience doing FG work and it is readily available locally.
I gat all the latex stripped Tuesday night and sanded and laid down the first coat of resin last night. Remember Bondo is your friend!
Greg~ :D
greglaw
Images: 65
Users browsing this forum: Google [Bot] and 10 guests
