aluminum skin
aluminum skin
Postby TD4FREEW/CTD » Sun Oct 07, 2007 11:42 pm
what kind of ally do people generally use to skin a TD? what have people paid? is it a cost effective material vs others? i would imagine something in the 3000 series of about .050" thickness? what kind of finishes to people have? polished? grain? what method are people using to secure the skin?
TD4FREEW/CTD
Postby madjack » Sun Oct 07, 2007 11:45 pm
....we use .032...don't know what series...mill finish...just float it and let the trim, fenders, outer accesories capture it in place....
Postby TD4FREEW/CTD » Mon Oct 08, 2007 12:01 am
i dont have much experience with sheet metal, i just know 3003 is nice and flexible and does not fatigue easily. takes shape well too.
TD4FREEW/CTD
Postby Sonetpro » Mon Oct 08, 2007 6:30 am
I used 5005 clear anodized. .040 on the sides, .063 on the roof. The .063 was a bear to bend around the radius.
I used anodized because I built it for a beach camper and didn't want the salt spray creating a maintenance nightmare.
I compared the costs and it was about the same as if I would have used Filon.
http://www.saf.com
Sonetpro
Images: 107
Postby james tillitt » Mon Oct 08, 2007 7:42 am
What is the cost of different thicknesses and finishes? Is there any reginal differences in prices?
james tillitt
Images: 18
Postby Nobody » Mon Oct 08, 2007 7:55 am
james tillitt wrote:What is the cost of different thicknesses and finishes? Is there any reginal differences in prices?
Aluminum prices have been & continue to be pretty volatile, & location definitely makes a difference in price/availability. .040" is generally accepted as a good thickness tho madjack's Aligator Tear did well with .032. I used .063 diamond plate as trim on front & lower sides & as Sonetpro said, it's a bear to bend. Finish ranges from standard mill finish thru brushed, anodized, painted, & a few even have highly polished; your choice. Whatever you feel comfortable working with should do OK :thumbsup:
Harvey -
Nobody
Images: 342
Postby james tillitt » Mon Oct 08, 2007 6:41 pm
I don't mean to highjack this thread. But, I am considering changing my Lil Bear from the white skin to a raw or anodized aluminum finish. I would like to know approximately what this would cost. I have also kicked around the idea of different paint schemes (to include a mock woody theme) and would like to know what's involved $$$ in a re-skin (either mill finished or anodized) in a .040 thickness. :thinking:
james tillitt
Images: 18
Postby Canuck » Mon Oct 08, 2007 10:20 pm
james tillitt wrote:I don't mean to highjack this thread. But, I am considering changing my Lil Bear from the white skin to a raw or anodized aluminum finish. I would like to know approximately what this would cost. I have also kicked around the idea of different paint schemes (to include a mock woody theme) and would like to know what's involved $$$ in a re-skin (either mill finished or anodized) in a .040 thickness. :thinking:
I just bought 2 sheets of .040
1 sheet was 5x8
the other was 5x10
total cost was just over $200
Canuck
Postby jeepr » Tue Oct 09, 2007 8:52 am
1 sheet was 5x8
the other was 5x10
Local place or online? I am not having much luck finding 5' widths.
Mike C.
jeepr
Images: 38
Postby sdtripper2 » Tue Oct 09, 2007 10:55 am
Mike C:
Here is a couple of sources in Michigan
Sourcing examples:
Factory Steel & Metal Supply
http://www.factorysteel.com/
Chart to scope out and select your 3003-H14 stock from Factory Steel
http://tinyurl.com/yxgsrg
Note: (For Roof - They have .050" 60" x 120"
Metal Supermarkets:
Store finder clicky
3003-H14 .040" 60" x144" *The sweet spot*
http://tinyurl.com/yk8xrw Click on the #2 row ALUMINUM SHEET 6061 - T6 to get details
5052-H32 .050 60" x144"
You drill down here and you will find
stores located in Livonia & Troy MI.
sdtripper2
Search Garoux
Images: 168
Postby Sonetpro » Tue Oct 09, 2007 11:42 am
If you order over 200lbs from http://www.saf.com they will ship it free. I had to use .063 for the top because that is all they had that was 5' wide. My order was a tad over $700 but I ordered all of my extrusions from them also. Great service.
Sonetpro
Images: 107
Postby jeepr » Tue Oct 09, 2007 7:33 pm
Thanks sdtripper2, I need to call or stop by one of those places. I was hoping for some around .32-.35 or so.
That 3003-H14 might be the ticket.. :thumbsup:
I need to do some reading on the different grades of aluminum.
Mike C.
jeepr
Images: 38
Postby Canuck » Tue Oct 09, 2007 8:11 pm
jeepr wrote:
1 sheet was 5x8
the other was 5x10
It was local.. kinda... about an hour from me in London Ontario
Unlimited Metals
519-457-4151
they told me they have more outlets.. but i didnt ask where
Canuck
Postby rbonner » Tue Oct 09, 2007 9:57 pm
You might try your local A/C supply houses. One of my local ones I use carries it for $65. a sheet in mill or white finish.
If you dont start, you,ll never get finished! http://s224.photobucket.com/albums/dd170/RonBonner/
rbonner
Alclad verses un-clad
Postby 3hansens » Wed Oct 10, 2007 7:09 am
A question for those of you who have polished their trailers: Alclad or not? Alclad verses un-clad -- each comes with its own advantages and drawbacks (cost, relative difficulty of polishing and keeping polished, level of shine, susceptibility to damage, corrosion resistance, etc.). If you were skinning a trailer that you intend to keep polished, which way would you go? Thanks...
3hansens
