by grant whipp » Tue Oct 09, 2007 1:24 pm
Canuck!
Any good piano hinge (stainless steel, aluminum, chromed steel) of about .060" thickness will work just fine for your application, mounted with the leaves between the door and door frame. Just remember to offset the door out 1/8" so that the door won't "bind" the T-Molding & Door Seal in the closed position. In your case, I'd recommend one that is 3" wide in the open position.
I typically trim out the edges (hinge side) with Edge Molding before installing my hinge, so it will have that finished look ... and I also run a piece of Drip Molding down in front of the door hine to help keep rainwater from being driven into the hinge while towing down the highway (even though I run a strip of weather seal between the hinge leaves).
Drop me an e-mail at
[email protected] and I'll be happy to shoot you a drawing!
Good Luck, and ...
CHEERS!
Grant
Celebrating
Retirement after over
32 Years of Building, Promoting, Supporting, Supplying, Living the Lifestyle, and Loving
Teardrop Trailers!"Life Moves a Little Slower When You're On Teardrop Time"The nature of Life, itself, is change ...
"Those who matter, don't mind, and those who mind, don't matter."
