Offset
Offset
Postby TRAIL-OF-TEARS » Wed Jan 26, 2005 4:33 pm
Here is a dumb question but what is the typical offset for wheels used on a tear? I would like to use either factory Ford Escape wheels (to match the tow vehicle) or Some smoothies. I don't really want normal trailer wheels. Do I need 0 offset, + offset, or - offset? and how much offset do I need? Thanks all.
Steve J.
Home built Camp-Inn clone.
GO SPURS GO
TRAIL-OF-TEARS
Images: 41
Postby emiller » Wed Jan 26, 2005 5:08 pm
Go to http://www.wheelvintiques.com/ they have an diagram to measure your wheels and will help you with what you need. 8)
emiller
Images: 157
Postby SteveH » Wed Jan 26, 2005 5:47 pm
Steve,
I'm using stock Jeep wheels, 15 X 7, and they are just right. If you want, I'll measure the back spacing?
SteveH
SteveH
Images: 42
Postby TRAIL-OF-TEARS » Thu Jan 27, 2005 10:01 am
Thanks emiller, nice site.
Steve that would be nice seeing as how we have the same axle. then I know I should be ok. Thanks
Steve J.
GO SPURS GO
TRAIL-OF-TEARS
Images: 41
Postby SteveH » Thu Jan 27, 2005 11:11 am
Steve,
The backspacing on my wheels is 5" (I know, pretty W I D E wheels for a tear), measured from the outer most portion of the rim to the hub surface. Keep in mind my walls set in line with the outside of the frame.
SteveH
SteveH
Images: 42
Postby asianflava » Thu Jan 27, 2005 5:50 pm
The smoothies that I got have 3.75in backspacing, with the tire it is right at 4in. If you don't have your axle yet then, offset shouldn't be an issue. You can order the axle to fit the wheels.
asianflava
