Sealing Aluminum trim around camper.
Postby jhouk2000 » Tue Nov 13, 2007 2:21 pm
I am building a painted camper. (exterior house paint on plywood) I would like to install aluminum trim around the edges after the paint has been applied to the camper. I am still undecide if I want to use Edge molding w/ an insert or just plain aluminum angle.
Is there any special steps I should take to keep water from getting under the trim?
Should I worry about water getting into the screw holes?
jhouk2000
Postby toypusher » Tue Nov 13, 2007 2:37 pm
I used polyurethene caulk under all of my trim pieces. You could probably use silicone also, but I have not used it myself. I would say that you should always put some kind of sealant in any screw holes that you make!!
toypusher
Images: 324
Postby Classic Finn » Tue Nov 13, 2007 6:00 pm
Weeeeell here in Scandinavia the moulding I use does have a formed rubber seal and under it lies a butyl tape all in one... 8) that is shaped to my trim or moulding.. here the 2 types Ive got.
How,s that for being different.. :lol: :lol: Im laughing now but sure wasnt when hunting for the moulding or trim.. :?
Classic Finn of the Arctic ;)
Classic Finn
Midnight Sun Voyager
Images: 146
Postby madjack » Wed Nov 14, 2007 4:42 pm
toypusher wrote:I used polyurethene caulk under all of my trim pieces. You could probably use silicone also, but I have not used it myself. I would say that you should always put some kind of sealant in any screw holes that you make!!
...that would be my advice as well.................................. 8)
Postby Rick Sheerin » Wed Nov 14, 2007 5:26 pm
I used plumbers putty tape. My trailers been in some pretty nasty downpours this past summer and not a leak to be found.
Rick S
1996 Casita Spirit Deluxe 17ft
Careful with that Axe, Eugene
Rick Sheerin
Images: 100
Postby spinnernut » Thu Nov 15, 2007 8:07 am
3M 5200 we use it to seal parts on the bottem and top of boats it does not leak you can get it at boat stores or home depot
Big Picture<img align="left" src= "http://www.mikenchell.com/forums/album_pic.php?pic_id=44265">
"A fluid falling from one container to another is my way"
Saith the SpinnerNut ~
Texican Party Animal Extraordinaire ~
I roll with the power of a Texican Train ~ laughing all the day ~
It doesn't cost anymore to go first class we just can't stay as long ~
spinnernut
aahooogaahman
Postby jhouk2000 » Thu Nov 15, 2007 11:17 am
Will the polyurethene caulk creat a good seal between painted wood and aluminum?
Should I place a dab of it in the predrilled holes before I put the screws in?
Thanks everyone for your help. I have a long way to go. :oops:
jhouk2000
Postby madjack » Thu Nov 15, 2007 11:26 am
....yes....yes and oh yeah...your welcome :D ...we put a heavy bead on the bottom of the top side, basicaly in the corner and squirt a dab in the predrilled holes before putting the screw(stainless steel) toit....
Postby toypusher » Thu Nov 15, 2007 11:29 am
Yes it should do a fine job.
Yes, I would advise that you do.
toypusher
Images: 324
Users browsing this forum: Google [Bot] and 7 guests
