How to do a trolley top...at least this is how I did it....
Postby doug hodder » Fri Nov 16, 2007 3:59 am
While there might not be much interest in this type of detail, I think it's a neat idea and this is how I did it, if anyone is interested.
First, after the cross members are installed between the walls, pick out what you think is going to be a nice profile. I tried to match the curve of the front of the trailer to the top. I planned on doing this to cut down on the harsh look of the flat roof line that I had with the vintage profile. Cut up a piece of hardboard for a template, use your imagination and many chunks of material.. This template is sitting about 1.5" high to allow for it to fit in on the upcoming longsills. Total lift to the top is about 7" overall
Mark the centers of the crossmembers, use each side of the walls for each crossmember, cuz, if you're off on the wall width, it'll show if you only use 1 side. Measure your top width from that center line, (faint lines in pencil on each side of the heavy black mark)...approx 12" on mine on each side.
Back up each crossmember with a piece of sacrificial wood, I used strips ripped from a 2x4. I screwed them with 2 screws on each end outside of the pencil marks.
Use whatever works for you to cut out the center ribs...I used a scroll saw, just make sure that you don't cut into the backing strips. The backing ribs keep the shape of the tear in place when you cut out the centers.
install and glue longsills along the cut out sides. For me...just epoxy and an air brad, no screws These allow you to attach the lifted portion and gives you a lip to attach the outer roof material to when the lifted roof portion is installed. Image
Install the cut out roof sides, again...no screws, just epoxy and clamps. Whether or not you choose to do a porthole as I have done, or any other sort of window, it's up to you. I just like the extra light that it gives. I laminate up the interior finish wood that I want and have it already finished prior to the install. I don't insulate the sides, but the ceiling will have 3/4" insulation. The rest of the ceiling has 1.5"
Install the lifted roof cross members. I only used 3/4 x 3/4" spaced at 8" and used material that I ripped out of the centers that I cut out. It will be insulated. A lot more strength will be gained once it's skinned on the interior and the exterior, and I didn't use any gusseting in the upper roof. I think once the skin is on the interior and exterior, that isn't going to be necessary, at least it wasn't on the last one.
More pics to follow as the skinning, insulation, wiring continue. Doug
Postby Podunkfla » Fri Nov 16, 2007 7:13 am
Superb How-To... Thanks Doug! :thumbsup: :applause:
<B>~ Brick
Image...Lots more pix here!
Podunkfla
ol' noodle haid
Images: 5
Postby toypusher » Fri Nov 16, 2007 7:27 am
Yes, that's some great stuff!!
toypusher
Images: 324
Postby Miriam C. » Fri Nov 16, 2007 7:29 am
:thinking: Now why am I thinking it can't be as easy as you have made it look. Wonderful tutorial... :thumbsup: :applause:
Postby Steve_Cox » Fri Nov 16, 2007 9:10 am
Thanks Doug,
At last, the mystique of the celestory roofline unravels. 8)
Steve_Cox
Images: 196
Postby Outlaw » Fri Nov 16, 2007 9:45 am
I love the trolly top feature. Thanks for posting the details :thumbsup: :thumbsup:
Eric
Outlaw
Images: 25
Postby bdosborn » Fri Nov 16, 2007 9:51 am
Doug,
I wondered how you dealt with the spars and keeping everything square. Nice post.
Images: 806
Postby Joanne » Fri Nov 16, 2007 10:25 am
Once again this shows why Doug is THE MAN! The technique makes perfect sense, but I certainly wouldn't have figured it out. Great tutorial Doug!
Joanne
New! My Camp Cooking Forum
Project Desert Dawg website
Universal Health Care
Joanne
Queen of Cast Iron
Postby del » Fri Nov 16, 2007 11:25 am
Thanks Doug. Now I see how it is done, may use the info some day on my third build. My next build I am looking at Andrews dink carrier, a trolly top under a boat seams pointless.
del
del
5000 Club
5000 Club
Images: 410
Postby Mike C. » Fri Nov 16, 2007 11:45 am
A well done step-by-step pictorial/tutorial. :thumbsup:
I have always been curious how you did it. :thinking:
Uncle M ( Mike )
Mike C.
our Uncle M
Postby toypusher » Fri Nov 16, 2007 12:00 pm
del wrote:Thanks Doug. Now I see how it is done, may use the info some day on my third build. My next build I am looking at Andrews dink carrier, a trolly top under a boat seams pointless.
del
Hey, Del! Why not put it on the Jellybelly build???? :D
toypusher
Images: 324
Postby milo » Fri Nov 16, 2007 12:30 pm
Gee thanks Doug. Just when I had my final, final design done, you had to post this how to. :? Well, Back to the drawing board. Later, Milo.
milo
always B dreamin'
Images: 9
Postby del » Fri Nov 16, 2007 12:48 pm
del
[insert hair pulling out emoticon here]NO.
del
del
5000 Club
5000 Club
Images: 410
Postby toypusher » Fri Nov 16, 2007 12:54 pm
:lol: :lol: :lol: :lol: :lol:
toypusher
Images: 324
Postby madjack » Fri Nov 16, 2007 3:19 pm
...toldja there would be folks interested in this...didn't I ;) .........thanks for showing us your engineering Doug, you make it look all so simple...hmmmmmmm :thinking: actually it is fairly simple.....
