I know cars have aluminum outer panels but I don't know if there is anything special about them.
If this has already been address, if some could point me to the right thread it would be appreciated.
Thanks
Rich
R. Maxwell wrote:I thank you for all the resposnses and information. This may be more than I planned for my first tear so I may leave it standard aluminum finish. Who knows when the time comes. Nothing ventured nothing gained right.
Rich
HossHoffer wrote:They have pretty well summed it up. We use two acids in aviation. Phosphoric acid to clean and etch and Alodine (chromic acid) to etch and add corrosion resistance. Scotch brite is the pad of choice to clean and scuff and is often used on a orbital sander. Of course for your application a good degreasing and light sanding with the scotchbrite should work fine.
