Seleecting the Right Flexride Half-Axle
Postby GeneH » Fri Dec 07, 2007 1:44 pm
I’ve reached the point in my frame build where I need to order my Flexride half-axles and am trying to make sure I order the right weight.
My teardrop will be an 11’ long, 5’ 2” wide Modernistic with a bolt-together frame based on the one Jerome posted photos of last year and I think just used for a 9,000 mile trip.
Using a spreadsheet that analyzed the weights for each 2” wide section of the teardrop (Hey, I am a first born and therefore anal about these types of things) my calculated weights are:
Frame: 350 lbs.
(Towable with 4 corner mounted leveling jacks, a spare under the galley and the tongue jack)
Completed empty Teardrop - 1200 lbs.
Loaded for Camping - 1550 lbs
(Includes 120 lbs battery; 60 lbs water; 40 lbs cooler; 30 lbs food; 45 lbs bedding; 30 lbs clothes).
With the wheels at 51” from the back of the Tear I calculated 180 lbs Tongue weight empty and 165 lbs Tongue weight when loaded for camping.
Based on these results I think I need to buy the 2000 lb. Flexride half axles.
Thanks in advance for your comments and suggestions.
Madjack I’ll be posting photos shortly.
GeneH
Images: 34
Postby madjack » Fri Dec 07, 2007 1:48 pm
Gene, personally I would get 2000#(pair) rated axles................................ 8)
Postby Alphacarina » Fri Dec 07, 2007 2:04 pm
Torsion axles work best when loaded to their rated capacity
For a 1500 pound trailer with 150 pounds on the hitch, the 1400 pound pair would be perfect for you - That's what I would go with
Don
Alphacarina
Postby SteveH » Fri Dec 07, 2007 8:49 pm
I have a 2000# rated axle under my trailer and it weighs about 1350 pounds loaded, and I'm happy with it.
SteveH
SteveH
Images: 42
Postby asianflava » Fri Dec 07, 2007 10:08 pm
Me too! Me too! Have 2K dexter on my 1150 trailer probably weighs under 1500 loaded. Dropped the tire pressure to 25 and it rides like a champ.
asianflava
Postby GeneH » Fri Dec 07, 2007 10:44 pm
Thanks for the guidance guys ... I ordered the 2,000 lb pair late this afternoon. When they get here I can fix the axle supports then wrap up the frame. :D
Now if I can just figure how to get it turned over once its finished since it is built upside down on the supports.
GeneH
Images: 34
