60" painted aluminum?
Postby Joe Staller » Thu Dec 13, 2007 1:02 pm
First time poster---6 month lurker.
I would like to sheath by 5X9 Benroy in white aluminum sheet. (Live in Arizona, want to reflect that heat away, and have low maintenance.) I can find 4' wide painted material locally, but have not found anything wider. I'm willing to mail order. SAF has told me that they don't offer painted material any wider than 48" either.
Does anyone have a source for 60" white aluminum wheet?
Thanks,
Joe
Joe Staller
Postby s4son » Thu Dec 13, 2007 3:11 pm
Here is a place I found on the net when I started building. I don't know anything about them so can't make a recommendation one way or the other.
http://www.harborsales.net/products.cfm?cat=Aluminum%20Sheets%20%2D%2D%20Coil
Scott F.
Are we there yet?
s4son
Images: 180
Postby doug hodder » Thu Dec 13, 2007 4:27 pm
You might try calling around to some of the local truck/trailer repair shops. They may have white on a 103" coil and they can cut off what you want. I've bought it from Fruehauf before like that, however it was just mill finish, but I know it's out there in white also. Too many white sided trailers on the road for it not to be. Just an idea. Doug
Postby madjack » Thu Dec 13, 2007 4:38 pm
...you might also wanna check any local sign shops................ 8)
Re: 60" painted aluminum?
Postby ssrjim » Thu Dec 13, 2007 6:56 pm
Joe Staller wrote:First time poster---6 month lurker.
Thanks,
Joe
Try Glendale Steel 59th and Bethany Home Road. Ask for their sign aluminum.
93079
ssrjim
60" wide white aluminum
Postby Aaron Coffee » Sat Dec 15, 2007 11:19 pm
If you have any race car shops or racers around they might be able to tell you where you can find it, modifieds and late models (circle track) cars have bodies made out of aluminum sheet.
Aaron Coffee
Images: 26
