as I have a good radius on the hatch lower section I measured the under frame out and it has to come out about 10.5 inches in order to pass from hitting the hatch when opening.
So from under the back frame I need to come down 1st 2 inches and then out the 10.5 inches.
Can someone please assist in drawing a holder or plate that could be installed under the frame with 2 or 4 screws or small mushroom type bolts that could be installed or bolted to the main bumper.
and then the question is as how to connect it to the bumper itself.
So this is what Im doing at the moment.
Photos of the back
I have an idea of using 2 plates the width of the frame 2 x 2 inches on either side. And with a possibilty to swing the bumber down when parked or camping and then being able to pull it into position when on the road.
Classic Finn
