Page 1 of 1
alumunum t-molding for 23/32 plywood????
PostPosted: Mon Dec 17, 2007 7:02 pm
by aquaholic14
I keep finding 3/4 t-molding for edging plywood, but cant seem to find the 23/32. Does anybody know where I can find some, or should just use the 3/4. Will the extra 1/16 cause a little lip on my ply??
thanks,
chad
PostPosted: Mon Dec 17, 2007 10:39 pm
by halfdome, Danny
Glue on a strip of plastic laminate (Formica/plam) on your 23/32" plywood to fill the gap. :) Danny
PostPosted: Fri Dec 21, 2007 12:21 pm
by Airspeed
You could just trim the T moulding down, it cuts easy on a tablesaw or bandsaw. Aaron
PostPosted: Sat Dec 22, 2007 12:59 am
by doug hodder
The difference is 1/32"...I'd just hit it with a good mill file to take it down, and a quick pass with some 400grit to smooth it. Just an idea. Doug
PostPosted: Sat Dec 22, 2007 2:11 am
by Nitetimes
doug hodder wrote:The difference is 1/32"...I'd just hit it with a good mill file to take it down, and a quick pass with some 400grit to smooth it. Just an idea. Doug
And angle grinder with an aluminum flapper disc on it will do both in one pass, quick too!! 8)
