So...Here is my first post. (2nd?) I do a lot of off road driving and camping. One of the problems I've encountered is dust making its way inside the trailer. To combat this, I've been thinking about 'pressurizing' the inside of our teardrop. I will use a low pressure, high volume, 12 volt air pump, similar to what is used to inflate river rafts. There will have to be an automotive type air filter on the intake end of the air pump mounted as far forward on the trailer as possible. Also, a small opening between the galley and sleeping quarters to equalize the system. What I am hoping for is air pressure to be blowing out through any microscopic holes or cracks that would normally allow dust to enter. The pump will be turned on via a switch in the tow vehicle, wired through the trailer plug connector. When you hit the dusty road, simply throw the switch...
Is there anyone out there who have already done this? Any suggestions would be appreciated.
Thanks, Ron
